0 Evo sportster Ignition Modules
Last Post: Stojan85
Last Post: jeffro57
Last Post: clivelive
0 Tuning a keihin butterfly
Last Post: shivaspear
Last Post: dtwaddell42
0 71 XLH Value?
Last Post: joe s
0 60’s XLCH front tyre
Last Post: davixlrtt
0 72 ih stroker advise needed
0 Allegheny National Park III
0 Hello from CT
Last Post: fafcpa
Last Post: Andy56
0 NOS cases
Last Post: BillPlayfoot
0 Facebook sales listing
0 Lectron Carbs: anyone used them?
0 Exhaust compatability?
Last Post: Racepres
0 2021 Iron Butt Rally
ebikerman (85), nalakk (80), blkjak (78), Dave.N (67), cousincletus (61), stretch7 (59), jockeyshift (57), juice900 (43), sportsterwheelies (41), live_loud (39)
883, rich, slow, sportster
Old 14th July 2020
mikaelson's Avatar
mikaelson mikaelson is offline
Sportster/Buell Model: XL883
mikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud ofmikaelson has much to be proud of
Default Can’t go over 70mph
Hello,
I’m having trouble getting my sporty 883 1994 over 70 mph.
I have installed single fire pickup and coil, both from Dynatek. I run original pipes with ”straight mufflers”. (Basically straight pipes...).
The bike is pretty responsive and runs extremely well otherwise, I have no problem getting up to 70mph, but trouble getting over it. I have checked compression and I have about 150 psi on both cylinders. I only run highest quality fuel. I was thinking it may be a vacuum problem in the tank?
But my spark plugs are not indicating getting too little fuel. The front cylinder seems to run rich and the rear pretty perfect, maybe a tad too rich...
Anyone got any good advice on how to localize or fix this problem?
It seems as the problem is only visible at high RPM. (Maybe a poorly jetted carb?)
I’ve added a picture that shows a pretty accurate representation of my plugs.
Thanks.
https://ibb.co/Ns3NLgf
Old 14th July 2020
denguy denguy is offline
Sportster/Buell Model: 1200
denguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond repute
Fuel filter?
Old 14th July 2020
Highly-Dangerous's Avatar
Originally Posted by mikaelson View Post
Hello,
Thanks.
Old 14th July 2020
You can try following some of the suggestions in this thread:
http://xlforum.net/forums/showthread.php?t=2076330
BTW - It's not a VOES issue...
Old 14th July 2020
NLXL's Avatar
NLXL NLXL is offline
Sportster/Buell Model: XL883DLX
Throttle cable to carb adjusted correctly so that the butterfly will open fully?
Sportsterpedia
Old 14th July 2020
cliffm's Avatar
cliffm cliffm is offline
Sportster/Buell Model: Superlow
Sportster/Buell Year: 2012
Sportster/Buell Model #2: S3 Thunderbolt
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Honda Areo
Other Motorcycle Year: 1986
cliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud ofcliffm has much to be proud of
Thumbs up
That's definitely a good check
Old 14th July 2020
wedge's Avatar
wedge wedge is offline
Slipping clutch?
Old 15th July 2020
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
What are your top rpm's?
Old 15th July 2020
Ireeman's Avatar
Asgardian
Originally Posted by Highly-Dangerous View Post
Alcohol blended fuels negate this.
It really has made plug reading challenging by former fuel information.
Actual plug pics would help.
Old 15th July 2020
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Other Motorcycle Model: FLHRI
Hello,
Thanks.
What RPM at 70 MPH?
Can you exceed that RPM in fourth gear? climbing a grade?
“Smooth roads, Blue skies and Green lights”
