Snippets
29th April 2022
Posts: 905 Sportster/Buell Model: Sportster XL883C / 1250 Sportster/Buell Year: 2001 Sportster/Buell Model #2: 2001 XL 883C/ 1250 Hammer
Chain Gear Case Fluid / Drain Plug Seals Inspection Cover Seals
Greetings Fellow Forum Members,
Finally got a new bike jack/ lift.
A Nice new tool Box.
Have some tools.
Got 3 New Gold Star Magnetic Oil Plugs with seal/o ring.
New Oil Filters with seals.
10 quarts of Spectro Heavy Duty Full Synthetic 20w-50 Motor Oil.
6 quarts of Spectro Heavy Duty STL Chaincase Gear Oil.
The funnel kit for filling chain case and motor case.
I AM READY TO FINALLY DO A FLUID CHAGE MYSELF. NOT!!!!
I forgot to buy:
(1). O ring and seal sets for the primary gear case drain plug.
(2). Gasket for the small round Primary Inspection plate.
Can any one help me with correct technical nomenclature and Harley part numbers?
Thanks in ADVANCE FOR ANY HELP WITH THIS.
Best regards,
FiftySixer
MY BUILD PARTS LIST: Hammer Performance 2004+ Big Fin 1250 kit with Flat top pistons, 2004+ XL 1200 Heads NEW built by Hammer,
Hammer 570 Cams, 42mm Mikuni HRS Easy kit, Twin Tech Single fire coil, Twin Tech Ignition, Hammer billet manifold,
S&S Roller Rockers, New Push Rods, Telescopic push rod tubes, Hammer 3" Air Cleaner & Filter,
Pingle High Flow petcock, 04+ oil pump & bronze gear/Chrome White Brothers 2 into 1.
29th April 2022
Posts: 9,685 Sportster/Buell Model: Sportster 883►1200 Sportster/Buell Year: 1994
30th April 2022
Posts: 213 Sportster/Buell Model: XLH1200S Sportster/Buell Year: 2003 Other Motorcycle Model: Harley Trike FLHTCUTG Other Motorcycle Year: 2019
Harley now has their own parts website. Scroll down to the year of your motorcycle to find the parts you need. Your welcome.
https://www.harley-davidson.com/us/e...s?aribrand=HDM
30th April 2022
Thanks IXL2relax and koolbreze,
I appreciate the tech support guys, thank you.
I’ll follow up on those.
Best regards, Walter
30th April 2022
Posts: 2,133 Sportster/Buell Model: XLCH Sportster/Buell Year: 2003 Sportster/Buell Model #2: XL Sportster/Buell Year #2: 1981 Other Motorcycle Model: FXDC Other Motorcycle Year: 2013
Replacing is the correct way
I look them over and often re-use
Steve
'01 Cyclone stock
'13 FXDC 96" stock
