0 Vintage Sportster seat?
Last Post: rocketnorton
0 Torque is never enough
0 CV on an Ironhead
0 Video - The Comfort Triangle - Set Up Your Harley for You
Last Post: cookiemech
Last Post: bagster guy
0 Hello from Gloucester UK
Last Post: 84rzv500r
0 stress killer
0 Conversion Kit Choices
Last Post: ReddTigger
0 Change engine sprocket
0 Primary
Last Post: koolbreeze
0 1974 XLH Rebuild
Last Post: Gearhead88
0 Sportster drags
0 Vital V-Twin Cycles
Last Post: vitalvtwin
0 You can't tour on that!!!
0 78 XLH project /new home
Wild One, Bugs (70), Blazer (67), OnDVirg (67), Buggyboy (64), TheChimp (49)
gear case pug gaskets, inspection plate gasket
Old 29th April 2022
FiftySixer's Avatar
FiftySixer FiftySixer is offline
Sportster/Buell Model: Sportster XL883C / 1250
Sportster/Buell Model #2: 2001 XL 883C/ 1250 Hammer
FiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant futureFiftySixer has a brilliant future
Default Chain Gear Case Fluid / Drain Plug Seals Inspection Cover Seals
Greetings Fellow Forum Members,
Finally got a new bike jack/ lift.
A Nice new tool Box.
Have some tools.
Got 3 New Gold Star Magnetic Oil Plugs with seal/o ring.
New Oil Filters with seals.
10 quarts of Spectro Heavy Duty Full Synthetic 20w-50 Motor Oil.
6 quarts of Spectro Heavy Duty STL Chaincase Gear Oil.
The funnel kit for filling chain case and motor case.
I AM READY TO FINALLY DO A FLUID CHAGE MYSELF. NOT!!!!
I forgot to buy:
(1). O ring and seal sets for the primary gear case drain plug.
(2). Gasket for the small round Primary Inspection plate.
Can any one help me with correct technical nomenclature and Harley part numbers?
Thanks in ADVANCE FOR ANY HELP WITH THIS.
Best regards,
FiftySixer
MY BUILD PARTS LIST: Hammer Performance 2004+ Big Fin 1250 kit with Flat top pistons, 2004+ XL 1200 Heads NEW built by Hammer,
Hammer 570 Cams, 42mm Mikuni HRS Easy kit, Twin Tech Single fire coil, Twin Tech Ignition, Hammer billet manifold,
S&S Roller Rockers, New Push Rods, Telescopic push rod tubes, Hammer 3" Air Cleaner & Filter,
Pingle High Flow petcock, 04+ oil pump & bronze gear/Chrome White Brothers 2 into 1.
Old 29th April 2022
Your should be able to select the proper section from this overall listing page at Ronnie's - 2001 883C Parts Diagrams and Parts Lists:
https://partsfinder.onlinemicrofiche...883-CUSTOM-(CJ)
https://partsfinder.onlinemicrofiche...ECTION%20COVER
https://partsfinder.onlinemicrofiche...ASE%20ASSEMBLY
For Sportster Tech Info:
Old 30th April 2022
koolbreeze koolbreeze is offline
Sportster/Buell Model: XLH1200S
Other Motorcycle Model: Harley Trike FLHTCUTG
koolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond reputekoolbreeze has a reputation beyond repute
Harley now has their own parts website. Scroll down to the year of your motorcycle to find the parts you need. Your welcome.
https://www.harley-davidson.com/us/e...s?aribrand=HDM
Old 30th April 2022
FiftySixer's Avatar
Thanks IXL2relax and koolbreze,
I appreciate the tech support guys, thank you.
I’ll follow up on those.
Best regards, Walter
Old 30th April 2022
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
Replacing is the correct way
I look them over and often re-use
Steve
'03 1250 NRHS stage two Lightning heads, SE536 cams, mik flat slide 42
'01 Cyclone stock
'13 FXDC 96" stock
