0 Greetings from NorCal/Nevada
Last Post: ZTatZAU
0 What is this shifter?
Last Post: RandallM
0 Calling ALL Sportster Baggers...Post your pics and what you did to your Sportster!
Last Post: JimVonBaden
0 WTB right front foot rest mount/brake pivot
Last Post: RandallM
0 Pegs vs floorboards
0 Traffic Stop
Last Post: amyst
Last Post: BWP 5p
0 2022 Sportsters
Last Post: ZCarFan
0 Need some info for my small stroker build
0 extortion
0 Video - STOP Saying Harley's NEED Backpressure! It's a MYTH!
0 A Reliable Engine
0 Speedometer
3 Rear galiper bracket spec.
0 .551 Cams in an EFI 1200
0 1958 XLCH? Maybe not... Help me ID this bike
Last Post: Jhbox13
Last Post: t120r
jurneyman (80), AdO650 (66), xlsport (64), darth (61), mcsmokinp (57), stalkie (57), unleashed66 (56), 66xlch (56), lownslow (50), hrg (48), Ironduke (46)
Old 5th December 2021
gotamotor gotamotor is offline
Sportster/Buell Model: Xlh
gotamotor is an unknown quantity at this point
Default No start after ultima ignition, thoughts?
Installed ultima ignition on 77 xlh
Blue and pink wires from modual to plug terminals on single fire coil, white wire from module and 12v wire from bike to center terminal on coil.
New resistor type spark plugs .40 gap, suppression core wires.
Static timed engine according to instruction, TDC compression stroke, TDC mark in timing inspection hole. Modual does its self test 1/4 second blink then, rotate module until red light comes on then back off till it just goes off. Tighten down
Set switches to advance curve setting #1,
Engine does not want to start but will pop with occasional loud backfire out of the pipes.
Has fuel flow, and confirmed it is getting spark at the plugs.
Any ideas what I may be missing?
Spark plug wires were reversed. Switched them and it started
Wasn't thinking about the fact I changed to single fire, used to plug direction not mattering with dual fire.
Thanks to tatro machine on YouTube
Sportster/Buell Year: 1974
Before I was able to post this you found the problem. I'm posting anyway.
Glad you found it.
When Using one single fire coil the blue and pink wire need to go to the proper terminals. Pink for rear cylinder, blue for front cylinder. Also the plug wires need to to be on the designated terminal.
Any chance you have them reversed? If unsure you could swap the plug wires as a check.
Old 6th December 2021
Glad you found it.
Thanks for the help need
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Model #2: '85 ironhead drag racer
Sportster/Buell Year #2: xlh
SHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud of
exactly what i was goin to post.you will like ultima
