0 Greetings from NorCal/Nevada
Last Post: ZTatZAU
0 What is this shifter?
Last Post: RandallM
0 Calling ALL Sportster Baggers...Post your pics and what you did to your Sportster!
Last Post: JimVonBaden
0 WTB right front foot rest mount/brake pivot
Last Post: RandallM
0 Pegs vs floorboards
0 Traffic Stop
Last Post: amyst
0 2022 Sportsters
Last Post: ZCarFan
0 Need some info for my small stroker build
0 extortion
0 Video - STOP Saying Harley's NEED Backpressure! It's a MYTH!
0 A Reliable Engine
0 Speedometer
3 Rear galiper bracket spec.
0 .551 Cams in an EFI 1200
0 1958 XLCH? Maybe not... Help me ID this bike
Last Post: Jhbox13
Last Post: t120r
jurneyman (80), AdO650 (66), xlsport (64), darth (61), mcsmokinp (57), stalkie (57), unleashed66 (56), 66xlch (56), lownslow (50), hrg (48), Ironduke (46)
  #31
Old 7th December 2021
mikethebike61's Avatar
mikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond repute
Originally Posted by jeffro57 View Post
I've done both, buy the harness, heat shrink and solder connections
And use MARINE grade heat shrink...water proof
I could be wrong....I'll ask the wife....she ALWAYS knows when I'm wrong......
Old 8th December 2021
Please be sure that you wire the Regulator Output on the Keyswitch-side of the Main Fuse or Circuit Breaker.
If you connect it directly to the Battery or on the Battery-side of the Main Fuse (CB), it will allow a failure of the Regulator to burn up the motorcycle. Wired directly will allow the Battery to supply 200+ amps directly into the Regulator & cause that wiring to become red-hot, potentially setting the bike on fire!
Despite the MoCo wiring some models with the Regulator connected directly to the Battery, that wiring is wrong - it needs to be on the other side of the Main Fuse (CB). They issued a correction in the replacement versions of the Regulator.
For Sportster Tech Info:
