0 wavers
0 900cc Cylinders
Last Post: Staffords
0 Fuel Sputter & Much More
Last Post: ronccc
0 New from Michigan
Last Post: Mmeader
0 Another Ohio Meet & Eat?
0 tachometer on 2012 Custom
0 Rear wheel alignment
0 low rpm problem
0 Hagerty Insurance
0 Help Identifying Pistons
0 Early Sportster Shock Absorber Disassembly
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 Mini chrome tachometer & speedo set for springer
Last Post: FiftySixer
0 05 carb rebuild no start
0 WANTED OEM HD BOBTAIL FENDER FOR 2001 Sportster
0 Nothing to See/Hear
Last Post: Tater66
Last Post: maltesefalcon
0 Starter wouldn't shut off
Last Post: Doc308
Jacquesnuenen (73), ocndaf (63), Wild Child (51), jetdoc1971 (49), Jmoses71 (49), Naugahyde (46), binksy (43), disasterousmark, KOOOPSD (35)
1200, coil, custom, horn, relocation kit
Old 15th September 2010
cminsel83 cminsel83 is offline
Sportster/Buell Model: xlc
cminsel83 is an unknown quantity at this point
Question 1200 custom coil relocation
Hi everyone! this is my first post.
I have an 05 1200 custom carbed. I would like to replace the side mounted horn with coil and ignition switch if possible. can i just use the horn bracket? will it still accommodate the choke? do i need to fab any other pieces? should i relocate the horn or just remove it? will there be any wire cutting if i remove the horn? are the kits sold on ebay a better option?
man, i have a lot of questions.
any advice/pics/tips are much appreciated.
thanks!
I know there are other threads about this, but not specifically about a carbed 1200 custom.
thanks again!
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
A custom is really no different than any other sportster as far as the ignition/coil/horn goes. I modified an old ironhead motor mount I had laying around to mount my ignition switch and coil to. Then I moved the horn to the down tubes. Here's a pic:
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Wow! that looks so clean.
I don't have much fabrication experience. Do you think my stock horn bracket would work as well as the "old ironhead motor mount" you used? Also, what did you use to attach the horn to the lower tubes?.. could i just unplug the horn and remove it?
thanks! nice bike.
Gone Gone is offline
Hello and welcome. I built mine using a combination of the motor mount and the coil bracket.
I did a bit of welding, filling in with JB Weld and powder coated it myself. I did away with my horn but I advise you to get a later model horn and install it somewhere inconspicuous. The wiring is very simple, should be just two wires, a yellow one which is the hot 12 vdc and a black one which is ground.
Good luck and remember to post pictures when you can.
H1 (Bud)
silencer057's Avatar
silencer057 silencer057 is offline
Sportster/Buell Model: XL883l
silencer057 is on a distinguished roadsilencer057 is on a distinguished road
We did something similar to what Jharback suggested on my buddies '99 except we just scrapped the horn. We did have to fab up a bracket though, but that only took about 10 minutes.
Now as far as my coil relo - I used the horn bracket off of a custom model with no fabrication at all. worked like a charm! pics are in my gallery if your interested.
awesome!!! these pics help so much. thank you.
the reason i'm asking about using my horn mount is because i read that guys were ordering this part to do the relocation on their nightsters and 883's that didn't some with side mounted horns. since mine did, i'm curious to if i could just swap the horn for the coil and switch.
let me know if this sounds stupid.
thanks silencer057!
that's exactly what i was looking for. now, if i could figure out how to mount the switch right above the coil (where that opening space is on the bracket) i'd be all set.
silencer057!,
is it easier to mount he switch where you have it?
Originally Posted by cminsel83 View Post
silencer057!,
Easier? Not sure, as I haven't tried other locations. I will tell you that it only added a few minutes to my overall wire tuck.
