Keep & Kill
....1
22nd January 2021
Posts: 309 Sportster/Buell Model: sportster xlc Sportster/Buell Year: 2005 Sportster/Buell Model #2: xlh 1200 c Sportster/Buell Year #2: 2005 Other Motorcycle Model: Triumph Kawasaki Other Motorcycle Year: 2018
Battery
HI
what battery size for XL1200c. one i have on it doesnt seem to keep its charge
its only six months old ,and connected a Optimate tender ,
just went to start bike had put it on full charge for half an hour ,,
Must say bike is standing its not being ridden
22nd January 2021
Posts: 3,180 Sportster/Buell Model: xls 1000 Sportster/Buell Year: 1980 Sportster/Buell Model #2: xls 1000 Sportster/Buell Year #2: 1983 Other Motorcycle Model: 1200 Chopper XL Other Motorcycle Year: 1990
Parts store will bench test yours.l
I'd also check for loose connections.
Plus I pull the 30 amp fuse before charging.
That way I can see if battery discharge is outside of battery and hot short in the wiring is to blame.
All of this before I buy a battery.
I'll let other replies recommend a new battery.
22nd January 2021
Posts: 137 Sportster/Buell Model: XLH1200S Sportster/Buell Year: 2003 Other Motorcycle Model: Harley Trike FLHTCUTG Other Motorcycle Year: 2019
Like above get the battery tested, even a new battery can go bad. Additionally, make sure your tender is connected and working properly. A Volt Ohm Multi Meter is your friend.
Have one of these (Big Crank) in my 2003 XLH1200S Works well
This is the one listed for your 2005 XLH1220C:
USA-Made Big Crank™ ETX14L Battery
Item #: ETX-14L
12 Volt / 12 Ah
220 CCA
• Dimensions: 5.88" / 3.44" / 5.75"
• Warranty: 1 Year Pro-rated
Made in USA MADE IN USA
Price: $87.95
https://www.batterymart.com/POWERSPO...&OEM=65958-04A
22nd January 2021
Posts: 22,250 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 "Totalled" By a Douche Other Motorcycle Year: 2012
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
4 Weeks Ago
I dont know if i can buy a big crank battery here in UK
thanks for your replies
4 Weeks Ago
Posts: 74 Sportster/Buell Model: XL1200T Sportster/Buell Year: 2017
My bike has stock HD battery and is into its 4th winter. So far so good.
My partners machine would be fine in the summer but fails to start in the cold weather even though it is on a tender.
I have just put a Yuasa YTX14L-BS on it. Only one start so far in the cold and it fired up right away.
4 Weeks Ago
Posts: 481 Sportster/Buell Model: 1200C Sportster/Buell Year: 2006 Other Motorcycle Model: Ducati Other Motorcycle Year: 1974
As it is six months old, is it in warranty?
