0 It's Glamazon's Birthday!
Last Post: bill smith
0 Indicators not flashing
Last Post: Gravitas
0 First start question
Last Post: 72HOGXLCH
Last Post: andy2175m4
0 HSR idle mixture screw
0 Q cams in 73 xlh ??
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
Stojan85 Stojan85 is offline
Sportster/Buell Model: XLH 883@1200
Sportster/Buell Year: 1988
Stojan85 is an unknown quantity at this point
Default Headers Exhaust Sportster 1988/2005 does it fit
Hello,
does the headers and exhaust of a 2004/2005 Sportster fit on an old 1988 Sportster? (Vance & Hines Blackout)
does it fit or does the headers / exhaust collide somewhere on the engine ... etc
Headers on the early Rubbermounts tend to run closer to the engine cases, sprocket cover cause the moved the rear master cylinder back behind the frame. Your earlier model has the rear master cylinder mounted onto the sprocket cover and might interfere with those exhaust.
I.B.A.#26543,
Hello Sportsterpaul,
I’m just noticing that too...
where does the new Sportster have its master brake?
What can I do ? are there any solutions?
thanks
http://www.customparts4less.com/WebR...BA/47501_2.jpg
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Other Motorcycle Model: FLHRI
Some of the rubber mount 2-1 systems will work on a rigid mount with mid controls. Most will not fit with forward controls.
“Smooth roads, Blue skies and Green lights”
The early rubbermounts carry their rear master cylinder mounted to an eleven pound casting bolted to the rear, bottom of the frame. In the filthiest place on the bike. They then ran the exhaust systems tighter to the bike. Later models had the master cylinder relocated to the sprocket cover as did the rigid mont bikes. So later made exhaust should be an easier fit. Just not sure when that change took place.
That isn’t to say you can’t make something work. I have an early SuperTrapp 2:1 mounted on my 2004”R”, but it required some judicious grinding of the footpeg support bracket as well as the underside of the brake pedal.
