0 how do eat an elephant,,
Last Post: Bikeaholic
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 su carb question
6 SPORTY BOBBER PICTURES
Last Post: Bryan83taco
0 What engine oil do you use?
Last Post: TUCCI
0 Too HOT to ride?
Last Post: PetesPonies
0 How tricky is it to replace dipstick trim from oil tank?
Last Post: burely
0 Buell special
0 Happy Birthday Mrs. Folkie.
0 Another clutch Question
Last Post: wrkdWS6
0 CV Carb - Transfer Ports
0 05 Sportster Manuals, Service & Parts
0 Cleaning clutch
Last Post: tussuck
0 my recent ebay purchase
2 My 1275 Hammer Conversion..
Last Post: wrkdWS6
0 Iron-shed
Last Post: smokey 2
0 Frame bracket
0 top end noise
1200, electrical, sportster, starter, xlh
Old 9th March 2016
Mojave3555 Mojave3555 is offline
Mojave3555 is an unknown quantity at this point
Default 2003 XLH 1200 stater keeps cranking
i recently aqquired an XLH with ape hangers and when i turn the key everything is normal but when i put the kill switch to the "run" position the bike cranks like im pressing the start button but will not start because there is no spark can anyone help?
Old 9th March 2016
Graywolf Graywolf is offline
Look for pinched wires in the right handlebar button cover.
Graywolf
Old 10th March 2016
if I remember right, power to on/off, power jumped to start button, only operates when in run position, could be starter button or cross wired
Old 10th March 2016
sportsterdoc's Avatar
You passed the memory test...you may now pass Go and collect $200!
Yes, stop/run powers start switch.
In this case the w/bk from the stop/run may be pinched to the bk/r to the starter...or the start button contacts may be fused together.
