0 Lifters Comparison
0 Generator removal
0 mixing brake parts
0 Spark plug discrepancy
Last Post: Ted Town
0 Hello from the uk I just got my first Harley!
0 4 Speed Stator Replace
Last Post: Parker 1000
0 T bars or Apehangers???
Last Post: Elzer0
0 Long overdue intro
6 English newbie
Last Post: spamer80
0 did the quiet baffle install short shots
Last Post: 201648Rider
0 S&S MGAL carb
0 Washer under brake shoe assembly?
Last Post: Kingrabbit
Last Post: Joe_jeep
0 2018 does not start - no speedo power, no blinker, good battery
0 Power cones
6 1983 Ironhead- Final wiring
Last Post: Attaxic
0 compression low?
0 Windshield Bug
0 Simplified Wiring and Bars
0 Starter Help - Need Help Diagnosing
Last Post: hala_madrid
0 .551 Cams in an EFI 1200
Last Post: Ghostdog
bendix, carb, float, leak
Old 26th September 2014
bsaman's Avatar
bsaman bsaman is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1972
Other Motorcycle Model: BSA Spitfire
Other Motorcycle Year: 1968
bsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to all
Default Help me with the physics of the Bendix float
Bike: 1972 XLH, stock air cleaner and pipes
Carb: Bendix with genuine Zenith rebuild kit
If I ever forget to shut off the fuel petcock, my Bendix carb leaks fuel from the accelerator pump. If I walk in the garage and I smell gas, it's a sure bet the petcock is on. No gas smell = petcock is off.
I've read through a handful of posts regarding this (here, and here, and here) and I think the issue may be with the float height. Sounds simple, but is it?
The float rises as the bowl fills and, as it rises, it pushes against the needle. If I flip the carb over and find that the 3/16 drill bit fits perfectly, where do I go from here? Slightly bigger or slightly smaller drill bit?
My guess is < 3/16" will raise the fuel level, and anything > 3/16" will lower the level. Is this correct?
bsaman's Avatar
On a related note, when I rebuilt the carb and checked float height, I did so without gasket. There are posts in the discussions I listed above regarding whether the instructions that "the bottom surface of the float should be 3/16 inch from the gasket surface" means with or without. I read "gasket surface" as meaning the surface that the gasket lays on, but others read it as the surface of the gasket.
Who knows? I'll probably reset it with the gasket in place if the answer to my question above is "use a bigger drill bit".
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
And you've got the float assist spring installed and pushing the right direction?
I've forgotten the petcock on mine a few times and never had a problem, but it sounds like yours would eventually leak all of your fuel into the crankcase.
I think I would disassemble the carb and hook up a fuel supply to it and check the needle and seat for proper functionality.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
doodah man's Avatar
did you put a new float needle in with the kit? if it's the old needle look to see if has a wear ring around where it fits into the carb body when it shuts off the fuel supply, also check where the needle seat to for wear. current needle full metal, or rubber tipped?
bsaman's Avatar
New rubber-tipped needle. The old one was worn as if it had been held against the seat to long; a sort of curved point.
doodah man's Avatar
Originally Posted by bsaman View Post
...The old one was worn as if it had been held against the seat to long; a sort of curved point.
all metal? it can be reconditioned. the newer stuff with the viton/rubber tip, apparently does not play well with today's "gasoline". may or may not be the problem you have, just food for thought...
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
Alright I'm gonna add a new twist to this,I call it the lean factor.The 3/16th is meant for a stock bike with stock kick stand.I think like my bike has way to much lean for I have 8" over on tubes and a kick stand that is sort of bend and it leaks out the over flow.
I think one member here cut the viton off the needle and that worked for him.Seems to me back in the day they didn't have the rubber tip.So what I'm saying is you just have to play with the float setting but you also don't want to be running out of fuel when your buddy on the Evo is trying to run off and leave you.The 3/16th is what's recommended but not the only setting that'll work.I always shut fuel off on all my bikes always have.
Murphy's Law :vvet:
simeli simeli is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 69
Other Motorcycle Model: Sportster
Other Motorcycle Year: 70
simeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud of
While I always shut off the fuel I also run the bowl dry after every outing, this allows fresh gas into the carb for every start. Unless you have some serious lean to your bike 3/16" should be plenty, look to the seat, needle or spring, also look to the check for the pump.
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
+ 1 ezmerf,,,,,,,,,, sage info and advice.
Old 27th September 2014
bsaman's Avatar
Well, going back to the original requests: can anyone clue me in on the float adjustment? If I want to raise the float (shut off fuel earlier) and I'm holding the carb upside down, which way do I bend what?
