0 Crank Seal Missing; Is My Engine Damaged?
Last Post: MkC
0 Stock (?) 1974 cobra style seat won't fit.
0 Show us a picture of your truck
0 2004 ICM
0 Getting Hammered
Last Post: carbonizedeyesockets
0 Proper XLCH
Last Post: 11B40
Last Post: geekonabike
0 Do people notice your bike?
0 Black Bike Bible
Last Post: Kokopeli
0 It's me - Kokopeli.
Last Post: Kokopeli
0 Possible air leak?
Last Post: noprobrobb
0 01 sport 883 (Shortest Shocks)
Last Post: RDHenley
0 Power cones
Last Post: JonesL
0 T bars or Apehangers???
0 V&H Short Shots Pipe Test - Mild 1250
Last Post: robbie202
0 Help Identifying Old Screamin Eagle Slipons
Last Post: FiftySixer
Last Post: SwissXL
0 Help!!!
Loneduck1, Doug (71), PAS858 (46), Clanure (42), FF95EMT (38)
1991, 883, clutch
Old 10th April 2015
AGHD AGHD is offline
AGHD is an unknown quantity at this point
Default Clutch adjustment problem
Hello.
Today I was going to adjust the clutch on my 1991 883.
This is how it looks, the whole thing is stuck and I can't even get it out.
I thought the spring was supposed to be on the outside?
Am I stupid or what is going on?
Thanks.
Old 10th April 2015
Picture (I hope):
Old 10th April 2015
Or here, I'm tired now, sorry..
http://sv.tinypic.com/view.php?pic=2uikxhy&s=8
Old 10th April 2015
ReddTigger's Avatar
TRY THIS..
States I've Ridden in
71.3 hp 70.8 tq
Old 10th April 2015
Sweet Terry Smoove's Avatar
Sweet Terry Smoove Sweet Terry Smoove is offline
Senior Bike Builder
Sweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond repute
that is backwards.
Old 10th April 2015
hmiller's Avatar
hmiller hmiller is offline
Sportster/Buell Model: 883
Other Motorcycle Model: BMW K1200GT
hmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud of
Yes, backwards.
Hold the adjuster and spin turn the center "shaft" with a screwdriver
Old 10th April 2015
Folsoml's Avatar
Folsoml Folsoml is offline
Folsoml will become famous soon enoughFolsoml will become famous soon enoughFolsoml will become famous soon enoughFolsoml will become famous soon enoughFolsoml will become famous soon enoughFolsoml will become famous soon enough
Looks at this diagram to see how it should be. http://partsfinder.onlinemicrofiche....TCH%20ASSEMBLY
My Current Bikes: 1980 Honda CB900C, 1983 HD XLH Sportster, 2007 Yamaha Vino
Old 11th April 2015
Thank you. It's my first Harley and my first post. Been reading alot here though.
It seems the previous owner did everything backwards. You should have seen the brake fluid.
Had a few hours sleep now..
hmiller, are you saying that the center pin can be adjusted with the locknut in place and that everything will come loose from the center pin?
Do I turn it counter clockwise?
Old 11th April 2015
JDRAKE4200's Avatar
JDRAKE4200 JDRAKE4200 is offline
Sportster/Buell Model: XL1200
JDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enough
I could be mistaken but I think you turn it clockwise to take that off. Guys please correct me if I am wrong.
Old 11th April 2015
ReddTigger's Avatar
Take a small screwdriver and turn that adjuster screw inside the nut.. I think that you'll need to turn it (screw) clockwise to remove the nut.. but you should see the nut move as soon as you start one way or the other..
once the nut is removed,take off the spring,, and re-install it the proper way, with the flat part of the nut facing the ramp of the clutch and the shoulder facing out.
take all slack out of the clutch cable, and then tighten the adjuster screw until you feel resistance... not too much resistance.. then back off a 1/4 turn then install the spring onto the outside of that.
