0 Low Profile Scissors Lift
0 2019 xl1200 suspension upgrade
0 Who runs 70wt. oil
4 greetings from quarantine!
0 XL Parts '04 up
Last Post: Jcolleyoh
0 '04+ Starting Issues, Do You Have Them? - Poll
0 1960 XLCH in the UK
Last Post: chilly
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: vagrant318
0 Oil Leak ??????
0 XR1200 for trail riding
0 Intake seals, glad I checked them
0 Sportster Tank Art
Last Post: Bryan83taco
0 Why cafe a sportster?
Last Post: Merch131ho
0 Spark Plugs
Last Post: Joe_jeep
0 74' XLCH wiring question
0 Resto-Repair 84 ironhead
0 Diagnostic code ?
0 No spark
0 FNG from Oregon
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
Old 27th May 2019
1mellom8 1mellom8 is offline
Sportster/Buell Model: XL1200 S
1mellom8 is an unknown quantity at this point
Cool 1997 Sportster S putting +4 front forks?
any advice? any good kits? I think the S has a little different forks than regular sportys?
new to this bike!
Old 3rd June 2019
Diogenes415's Avatar
Diogenes415 Diogenes415 is offline
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL883C
Diogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond repute
Franks Forks (AKA 'Forking by Frank' back in the old days) has been in the biz for a long time... that goes a long way. TC Bros sells 'Moto Iron' forks which seem to be decent. I went 6 over on my '98 and love the added clearance and the ride. Although I can feel the difference at low speeds it's not as crazy as people make it out to be. I can predictably control the bike with one hand (I made my bars only 22" wide) and with any speed over ~20 mph I can't even tell the forks are longer. The bike tracks straight and true with 'no hands'.
Nope, it's a Sportster.
Old 4th June 2019
LocoLocal's Avatar
LocoLocal LocoLocal is offline
LocoLocal is an unknown quantity at this point
Following as I would like to do the same with my S. Would love to keep the dual disc front brakes though. I'll report back if I find anything!
Old 4th June 2019
LocoLocal's Avatar
Well, shucks, there is this...
http://www.chopcult.com/forum/showthread.php?t=46755
Old 6th June 2019
@locolocal thanks mate! that’s some great info. i’m looking into just swapping my front end with someone from a regular sporty. i don’t really care about the dual front brakes all that much
Old 7th June 2019
LocoLocal's Avatar
Good luck with the swap! Keep us updated.
I don't care much about keeping the adjustable suspension but would like to keep the dual front brakes. I think I will have to look for another model's front end if I want to stretch it a bit under those circumstances.
Old 18th June 2019
rezchug's Avatar
rezchug rezchug is offline
Sportster/Buell Model: 1200
rezchug is an unknown quantity at this point
It's okay +4 just looks like a welfare wannabe chopper.
Had +4 a few yrs ago but switched to a -2 wideglide fork.
It doesn't handle very good especially at highway speeds on corners but at slow speed its similar to stock.
If you try to go over +4 it looks very sad, almost pitiful especially when the guy is riding by a real chopper, it screams poor wannabe
Old 19th June 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Hey! you CAN get a larger tool bag under your bottom triple tree.
Old 22nd June 2019
super duper +1 on handling change
you will notice slow speed turns will have a higher stall speed unless you rake it to bring geometry back inline.
you will find a harsher ride on crappy surface since the angle of the dangle is changed
i doubt 4" will do it but there is the issue of pogo or harmonics at a certain speed.
this was a common mod back in the 60>70's and is an "OK" look. chopper is in the eye of the beholder, look at vintage hell's angles pic's and footage, even they accepted the look.
btw: been there, done that
Old 22nd June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Adding any more than 4" without raking it is what looks like a welfare chopper. +2 or +4 tops is acceptable.
I gained a little just putting the Intiminators in and running the same amount of oil. Dropped the rear 3/4" and stability is way better and gave it the look I was after. No more brake dive either.
