Last Post: motorfish
2 Your daily tunes...
Last Post: RDHenley
Last Post: ivanford
0 88ci Sport Rod
Last Post: CaptainZoop
0 900cc Pistons
Last Post: jsandidge
0 Help!!!
Last Post: rocketnorton
0 Oil amount
0 Stock pipes
Last Post: DéDé
Last Post: Oldmxdog61u
0 Proper XLCH
2 Humble pie
0 A Day in the Life...
3 2005 XL883 Standard for sale
Last Post: SLW210
0 The last of a dying breed...
0 '81 Gasket/Rebuild Questions
Last Post: Andy Hog
dave (71), Miami (70), MnKevin (65), bigdogbark (64), robby269 (60), larry p (58), MadDogXR, kev883 (56), 0ut1aw (56), Nu Viking (54), dlclark804 (51)
Old 13th June 2019
mikam123 mikam123 is offline
Sportster/Buell Model: Custom XL883
mikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of lightmikam123 is a glorious beacon of light
Default Brake light/hi beam question
Recently bought a 2001 883 custom, and currently, the gas tank is getting refined, so I figured it was time to change the front controls as the turn signal switch was messed up.
I got both the front controls switched and in the process of adding turn signals and a new brake/run light I found two issues. The first issue is the bike won't switch to hi beam on the front, is this because the bike is not all the way on? Or did I mess up the hand controls? The second issue is there doesn't seem to be any wire that turns on just the brake light, and not the run. I only found constant power on the wires and nothing that responds when the brake is engaged. Definitely new to wiring so there is a huge possibility that I just don't understand how the brake/run light works. I found wires that power the turn signals and all that seems to work well with the switches.
Old 13th June 2019
Do you have a Factory Service Manual? Are you following the Schematics?
The Hi/Lo Switch has an incoming BLUE wire that is the power for the headlight - Outgoing from that switch is a WHITE wire (Hi) and a YELLOW wire (Lo) to the headlamp socket... double check the switch connections...
Did you follow the precaution in the manual about the front brake lever?
http://sportsterpedia.com/doku.php/t...h_-_front_rear
The Brake Light is operated by a RED/Yellow wire... The front and rear brake switches are in parallel - Pulling the front lever or pushing the rear lever will activate that RED/Yellow wire with power...
It is VERY LIKELY that you did not get the front brake switch properly aligned when you worked on the hand controls - Double check the placement & alignment - It is very common to get this wrong...
Old 13th June 2019
I do have the factory service manual. I followed the schematic closely for the left-hand controls, however, I didn't have it when I did the right and possibly xxxxed up the alignment for the brake controls. I will recheck that. I am also going to recheck my wiring for the left. The brake/run light that I got only as two wires, so I am assuming one is ground (black) and the other is power. is this incorrect?
Also, thank you for sharing sportspedia with me that is an awesome resource.
Old 13th June 2019
If it's only two wires, it's likely that the light housing itself is intended to be grounded - then one wire is the 'always on' running light (taillight) and the other wire is used for the brake light (connected to the HD RED/Yellow wire)...
The bulb should be a dual element bulb (1157) and the low intensity element should be always on and the HI-intensity element is used for the brake light...
SP section on the taillight:
http://sportsterpedia.com/doku.php/t..._license_light
Old 13th June 2019
That was super helpful.
Just an update on the brake light solved. It is grounded to the housing, and when I hooked up the correct wires according to sportspedia (one to running, and one to brake) the brake light would only come on in acc and not ignition. I figured the ground might be bad, so I took apart the license plate bracket and sanded down all the bolt connections for better ground, and put it back together. The brake light switch is working now that I got the correct position and the light is correctly grounded.
One note, I did tear the rubber on the brake light switch as I didn't follow the correct procedure. But I glued on a little gasket on top and now it functions perfectly.
I have not checked the high beam issue yet.
Old 13th June 2019
Good for you and thank you for reporting the success so far.
