Last Post: burely
0 Seized 1200SPORT Fork Cap
0 Intake manifold
0 Screamin Eagle Wiring
Last Post: AntonieR
3 Shaky Dave Recovery
Last Post: Hornsmith
0 FS Front brake line from '03 45121-96A*
Last Post: slamtry
0 "S" model specific Q&A
0 900 heads contd..
Last Post: simonster123
0 Tank Paint Ideas
Last Post: MotorPete
0 Fuel tank urns
Last Post: ezmerf
0 wrong brake fluid
0 Trans corner fix
0 Anyone know where I can get one of these mini fairings?
0 98 s10
Last Post: ezmerf
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Oil hungry Iron Heads
0 Getting Hammered
Last Post: Bryan1976
0 exhaust gaskets
0 New member from snowy Colorado
0 new member
cobra0478 (76), Han (63), priell3 (59), Byrdman (55), jsta (53), YaeDio (52), chad.hart17 (47), doc (46), jfunk (46), lenainrouge (45), JohnDao (41), Razer883 (34), Slapchop68 (26)
Old 27th August 2009
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Sportster/Buell Year: 1988
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Thumbs up
I would just go with what Chuck said in post #4 of this thread... He's pretty accurate...
jgcable jgcable is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
jgcable is an unknown quantity at this point
With the bike off and the battery disconnected from the battery tender it immediately reads 13.25v. It eventually levels out to 12.68v.
I started the bike and remeasured... it reads 12.38v
I turned the headlight on and it dropped to 12.25v
I revved the motor and the voltage did not increase. I am not reading any overvoltage as stated in post # 4.
Question
I would next be looking at the battery for problems. What type and how old is it?
If it is a lead acid type, there may be dead cells/plates.
Its a brand new battery with the caps. When on the charger it charges up to 14.15v. It will hold a sufficient charge to start the bike after a few days.
I doubt very much it is a battery problem. Even if the battery was suspect it would still show being charged when the bike is running. There is no visible signs of charging of any kind when checked with a meter.
I mentioned this earlier but I will mention it again...
The stator/regulator connector was extremely hot when I went to unplug it while the bike was running so that I could check the stator and the regulator. It seemed to be much hotter on the side of the connector that leads to the regulator. I removed the regulator, cleaned the contacts that it makes with the frame so that they are spotless. That didn't do anything. The connector looks very clean and the pins are clean too. I assume the 3rd wire from the regulator goes to a relay that is mounted on the rear fender. That wire in turn comes out of the regulator and connects to the + side of the battery terminal. All that wire looks to be in fine shape too.
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Originally Posted by jgcable View Post
So I will assume there is no way to check the regulator without the bike running. My bike doesn't have a carb on it presently because I am having problems with it.
This morning I unplugged the stator/regulator connector and put one lead of my meter on one of the sockets in the connector leading to the regulator and the other one on the negative terminal of the battery. I was told I shouldn't have any voltage present. I tested both terminals and I don't have any voltage present nor are they grounded.
I tested it with the bike off and with the ignition on. I can't check it with the bike running currently.
You don't check the stator for voltage to ground..you check for continuity to ground! (with the bike off, that is) Resistance setting...
~Chuck
Occam's Razor...
XLF Tuning Stickies
ted's Avatar
ted ted is offline
Senior Master Bike Builder
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
And remember when checking alternator output, it is alternating current, not direct current. Heat at the plug suggests bad/dirty connection or the wires coming apart at the plug.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
I am using a Fluke 12. On the V-check setting if I touch the black and the red probes together the meter blinks telling me I have continuity. I have been using this meter for over 10 years to check continuity this way. On this setting the meter will also switch from AC to DC automatically when it senses either voltage. I can also test diodes in this mode.
The only other mode this meter has is the capacitance mode. I use this to test resistors, capacitors and potentiometers for their value.
I checked the stator pins using the V-check setting and I got no beep which means there is no continuity to ground. If there was.. the meter would beep.
What am I missing here??
Ted
I am going to go triple check that connector tonight to make sure its as clean as I think it is.
The plug and socket doesn't get hot until they are connected. Within a minute or so they start to get warm. After 5 minutes they are hot enough to not be able to touch. Unplugging them cools them right down.
WrenchAnRide WrenchAnRide is offline
Other Motorcycle Model: Triumph (chopped)
Other Motorcycle Year: 1970
WrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura aboutWrenchAnRide has a spectacular aura about
When checking the stator on a Triumph, one puts the test leads to both stator wires to form a loop and there should be continuity. Then one test lead to one stator wire, other test lead to ground and there should be no continuity, same/same for the other stator wire. This is also with the bike off.
In your case, when you touch a test lead to each pin separately and other test lead to ground, you're getting no continuity, right ? Same/same for each pin, yes ? Which I believe should be the case.......(I just replaced a voltage reg on the Sporty and the 2 pins plug INTO the wire connector coming from the alternator/stator. Not sure if your's is the same or reversed with pins facing the connector as it comes from the voltage reg. side ?).
Either way, whether it's male or female receivers from the alternator/stator side of the connector, is it O.K. to touch the test leads to both of those at the same time to form a loop ? And, if so, it should show continuity, yes ?
If I'm in the ballpark and you've got continuity between the 2 stator leads and no continuity from each stator lead to ground, then I'm thinking it's a voltage reg problem......
Old 29th August 2009
Charging system is fixed. It was the regulator.
