0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 JACKHAMMER 570 Cams!
0 Runs rough on highway.
Last Post: Rich L
5 Summer time heat
Last Post: Kbetts
0 NEW CRANK OPTION for 91-03 OWNERS: XR1200/Buell XB Crank Retrofits
0 Air Filter Soaks With Gas
Last Post: Wilkinson949
0 Sportsterpedia Progress
0 1981 ironhead xlh PROJECT
0 Oil Tank Cap doesn't fit right
0 Lacing a 21 inch wheel to a 19 inch hub
0 Hi from NY state
Last Post: brettxlch
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
Last Post: Bama Lee XLC
5 Why Are You Still Married?
Last Post: JaKaL
Last Post: oupa
0 Do people notice your bike?
0 WTF Happened
Last Post: jcn59
0 Spectro STL 75W140
0 Hoo rah for Missouri.
0 stress killer
0 2 into 1 exhaust build
0 Cv carb jet question
mailmanjohn (52), 93customsporty (52), markmopar (52), ironheadTX (48), Austin-W (47), dcarterjr (47), MaX_01 (35)
Old 20th October 2018
mikeLI_77's Avatar
That would be more than enough braking for the rear.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Originally Posted by mikeLI_77 View Post
If this helps at all.
Axel is the same from 89-03.
P/N#41563-77A
All Wheels 3/4” dia axle.
86-99 rims had 3/4" timken bearings 00-04 has 3/4" sealed bearings.
Thanks for the correction mike.
madnss's Avatar
[QUOTE=jordan1200;5708340]This looks nice but price isn't cheap.
https://www.freespiritsparts.com/en/...-1-2-inch.html
Sent from my SM-G930W8 using Tapatalk[/QUOTE
My buddies sister isn’t cheap either, rather expensive as hxll. But I call her when I want high quality performance that will last! Her cousin is cheap!!!! Just don’t look her in the eye!!! Haha take your pic!!!
jordan1200's Avatar
[QUOTE=madnss;5708380]
Lol wow
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
Old 21st October 2018
c1skout's Avatar
c1skout c1skout is offline
Sportster/Buell Model: sportster 1200c
Other Motorcycle Model: Royal Enfield / BMW
c1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud of
Do you want the newer caliper for looks? Just wondering because my stock 98 will easily lock the rear wheel, too easily, compared to my other bikes. I don't see what an upgrade would gain you over a properly working stock setup.
Jason's Sporty's Avatar
Jason's Sporty Jason's Sporty is offline
Sportster/Buell Model: Sportster XLH 883/1207
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1972
Jason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to behold
Yes it will bolt up no problem. I put a 2000 swingarm, brake caliper and wheel on my 1986.
The difference between the sliding pin type original caliper and the 4 piston solid type is night and day. You can feel everything it is doing and not just nothing and locking up the rear wheel like the stock one did.
jordan1200's Avatar
I want better stopping power. I changed the front to a 2000 dual disk and it is way better.
So I can only imagine that it will be that much better.
Also, having matched brakes from and rear is also nice.
jordan1200's Avatar
Yes they are but spacers are different.
