0 Scorpion Clutch / Mueller Easy Pull
Last Post: Four Speed
0 Gotta Start a Thread for the Streetfighter Too!
0 Tt
0 Shift Tower Interchangeability / 4 Speed Rebuild
Last Post: Fast-Shovel
0 Have You Seen This? (New Harleys)
Last Post: jammantoo
Last Post: Yakcm2
Last Post: Slojoe55
Last Post: lazyb8s
0 (How to Needed) TC88A ignition module donated to me
0 oil pump breather screen
0 Just bought the cheapest 2-1 on ebay.
Last Post: brianbbs67
0 whats your iron head worth
0 Shovester Sighting
0 Boardtracker Project
Last Post: JonesL
0 How Much Money Has Being An XL Forum Member Saved You?
Last Post: Black Bobo
0 ‘17 Roadster no start...
Last Post: ADK XL
0 EZ Pull clutch
0 Spark Plugs
Last Post: sltm1
5 Change Tranny Sprocket After Conversion?
Last Post: RAIDER0372
0 Xl/Buell drag bike parts
Last Post: Slojoe55
0 To crossover or not?
Last Post: The Crusher
0 1998 Sportster Ignition Problems
Last Post: james69
Last Post: Nate.evans
0 Big Bore Kit - What else is needed
NZstu's Avatar
NZstu NZstu is offline
Sportster/Buell Model: Xlh1200s
Sportster/Buell Year: 99
Other Motorcycle Model: Klx250s
Other Motorcycle Year: 2010
NZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud ofNZstu has much to be proud of
Default 48 air filter on a carb
Anyone tried to fit a sportster 48 stock cleaner on a carb model 91-03?
I had a search around but didnt find any reference for it
Sent from my SM-G950F using Tapatalk
Don't care what you ride as long as you ride
Old 6 Days Ago
Folkie Folkie is offline
Yes: it won't fit.
Why '91 - '03, BTW? What's wrong with '04 - '06?
Old 6 Days Ago
NZstu's Avatar
91-03 is what i have.
Was just wondering.. it looks line it may fit but i will heed your advice
Old 6 Days Ago
NZstu's Avatar
View of the back.
Are the vents on later engines the same spacing as the evo ones
Old 6 Days Ago
Someone tried one on an '04 - '06, and it wouldn't fit. Fitment on a '91 - '03 should be the same.
Old 6 Days Ago
Yes they are.
And it's still an Evo engine.
