22nd September 2007
Posts: 50 Sportster/Buell Model: xlch Sportster/Buell Year: 68
static time
I was wondering if anyone had a easy way to static time
22nd September 2007
Posts: 1,017 Sportster/Buell Model: xlch Sportster/Buell Year: 70 Sportster/Buell Model #2: Softail Springer Sportster/Buell Year #2: 2006
Here's how I do it on my '65 (I'm assuming yours is a '68)...
1. I remove the timing plug (located on the primary side of the engine just below the cylinder jugs in the middle).
2. I have a distributor so I remove the distributor cap.
3. I remove the spark plugs.
4. I slowly ratchet the kick starter until the vertical line on the flywheel is in the center of the timing hole (plug I removed).
5. I either use my good eye or use a continuity tester and turn the distributor cam to the fully advanced position. The points should just be breaking if it is statically timed correctly..other wise, I loosen the distributor and turn it until this happens!!!
ps...it is easier to have someone look it the hole to line up the vertical line while your ratcheting the kicker...like I say, my year is different than yours and I'm not sure if my method applies to your year. Someone from the forum will confirm it!
Sam
23rd September 2007
so basically finding my smallest feeler gauge and stiking in in between the lobes just untill it releases ?
23rd September 2007
Posts: 187 Sportster/Buell Model: SPORTSTER XLH Sportster/Buell Year: 1973
i stick a flat screw driver in the timing hole til it touches the fly wheel lightly and push the kicker, when it hits the mark you'll feel it and hear it click
23rd September 2007
Posts: 282 Sportster/Buell Model: 1973 early xlh
I take out the points cam and with a dremel put a notch (line) into it,this way i can put it into full advance by using a thin screwdriver or a pick.Just make sure you dont go to high up where it will affect the points,I also put two notches one each on opposite ends.Makes it faster for me.
