0 Fact or fiction?
Last Post: Yakcm2
0 supply oil line seeping
Last Post: RDHenley
Last Post: RDHenley
0 Primary Cover Starter Shaft Needle Bearing
Last Post: 72 Ironhead XLH
0 oil return for stroker
0 Cheap 7200B bearing = NO!
0 Holiday sale on 1250 kits through 12/31! $495 any kit big fin or small!
0 2002 Sporty backfire through carb
Last Post: budoka
0 Selling a complete bike vs parting out
Last Post: Lukidj
0 stress killer
0 hi all
  #291
Old 5 Days Ago
Interesting repair Max.
What causes the crack, geometry getting out?
Honestly, I've been through a bunch of em and I've never seen a crack there.
Old 5 Days Ago
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
On the outside, usually freezing with water. All the time on marine and race engines.
The lifter valley will crack from from freezing, but it will crack from stress. The casting is thin in that area, and can be thinner than normal from core shift.
If look at the photo of the valley, you see a rust stain. That block passed a pressure test, but it was leaking a little bit at times. A magnauflux test showed the crack.
They made something like 80 million SBC’s. An avid hobby builder might never see one cracked. Most automotive machinist have seen a few.
Sleepy Labeef rides again!
Old 5 Days Ago
I did noticed the stain.
I've had a few blocks fluxed but mostly just had them dipped.
It's just hard for me to visualize enough water getting past the SBC intake to freeze the valley.
In Pontiacs I could see that happening easier without the hood.
Marine engines I hadn't considered.
Old 5 Days Ago
Maxeffort's Avatar
It’s engine that use straight water. and crack from the ice inside the water jacket. Freshwater cooled boat engines and racing engines that can’t run anti freeze. The owner forgets to drain and winterize.
Old 5 Days Ago
Alright, that makes sense.
No antifreeze and all bets are off.
But, that has nothing to do with the SBC (as it was intended to be used anyway).
Old 5 Days Ago
Originally Posted by ZCarFan View Post
The SBC was OK by the mid 60s, but they still broke sometimes. Most were OK.
Now you got me thinking about a 283. Wish I had a few of those back.
Old 3 Days Ago
84cj 84cj is offline
Other Motorcycle Model: Yamaha Virago 1100
Other Motorcycle Year: 1995
84cj is an unknown quantity at this point
1985 Mercury Topaz....... POS
Old 1 Day Ago
Glamazon Glamazon is offline
Sportster/Buell Year: 2014
1975 Sunbeam Rapier https://i1.wp.com/www.aronline.co.uk...size=600%2C414 a classic POS! 5 years old and rusting faster than I could weld it, I burned shoe leather more than I burned rubber
Old 1 Day Ago
Folkie Folkie is offline
And highly dangerous...wtf is that!
It's a recycled Fiat, isn't it?
Old 1 Day Ago
Nibelungen's Avatar
definitely
34 cv motor of the Fiat 850, mounted cantilevered on the rear
front and rear chassis of the Fiat 126
center chassis of the Fiat 127
a rejected project of Fiat...
then a low cost car built under licence by the controlled Seat... and designed for the then markets of Portugal, Holland, Germany and Spain (sold as Seat) and the then developing markets of Turkey and South America (sold as Fiat) in the 70s
very, very ugly...
very very robust....
very very cheap...
if the end justifies the means... then who does justify the end?
Similar Threads
OIL CHANGE!!! IrishThug Dealers, Stealers, Indys and Parts Dealers 26 26th April 2005 20:00
Mirrors: How important is it to see behind you? KLars Sportster Motorcycle General Discussion and Problems 37 8th April 2005 17:09
