0 roadside belt change
Last Post: jazzman
Last Post: commando57
Last Post: Whitewalls
0 Right rear turn signal out 2002 XL1200C
3 Shaky Dave Recovery
0 1970 XLH 900 color?
0 Hi From Atlanta
Last Post: ZCarFan
0 Sleeve cylinders?
0 Options for SE a/c cover
Last Post: tussuck
Last Post: hexnut
Last Post: tussuck
0 TC88A Programming Hardware
0 Ironhead in the uk
0 External breathing systems
0 Sportster Cobra seat
Last Post: duffy
2 My 1275 Hammer Conversion..
Last Post: Firehawk
0 H-D 2019 Financial Results
0 cam lobes
0 The B's Knees...
Last Post: shgrier
0 77 XLCH oil line routing
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
  #6011
Old 11th June 2019
sml1226 sml1226 is offline
Discovered oil on the bottom of my clutch cable. Looks like the end at the primary is leaking a little. Any recommendations for a good clutch cable? Just buy another OE, or look elsewhere?
Also finally broke the seized up O2 sensor plug loose on my front pipe, and the head is mangled, so it's "tuning time" again until I get some new 18mm plugs. O2 sensor is back in and I get to see how bad I've had this carb set up since I changed the intake.
Originally Posted by boomerguy View Post
When you put the forks back together, try these instead of the OEM fork caps. Getting the caps back on while pushing the springs down is an olympic sport event. If you have to go through the effort, try these and you will never dread replacing the fluid again.
https://www.jpcycles.com/product/230...tube-top-plugs
They are OEM quality and definitely worth their very high price.
I've never understood how those would be helpful. Unless you're just dumping a fixed amount of fluid in there and calling it good, you'll need to pull the caps anyway. But, my caps have been in and out a half dozen times in the past six months and I've never had any trouble doing it, so maybe I just don't see the need.
Old 11th June 2019
xlerate xlerate is offline
Other Motorcycle Model: Yamaha FZR1000
Other Motorcycle Year: 1988
xlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant futurexlerate has a brilliant future
Default Fork caps
I used the appropriate size socket with a 3/4' drive and a 3/4" drive 10" (or so) extension to find it straight forward to do. No damage to the chrome caps, either.
2006 XL1200R in Yellow Pearl with wire wheel option; 30t trans sprocket; SE Heavy Breather a/c; SE II slip-ons; S&S IST ignition; 48 pilot, 185 main, CVP EZ-just mixture screw; HEL braided brake lines; Race Tech Gold Valves, Ohlins S36E shocks, Superbrace; Dart screen, Mustang Vintage Solo; JH570 cams installation underway.
Old 11th June 2019
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
Is there something wrong with the cable?
IIRC there's an o-ring on the fitting where the cable passes through the cover. That's likely the source of your leak.
Old 11th June 2019
Kawa110 Kawa110 is offline
Kawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant future
Default What did you do for your sporty Today?
New black control levers, Clutch lever perch, clutch cable, and drive belt(to go on)changed the oil, primary oil, spark plugs. Installed a CVP carb tune kit. Having rear wheel balanced today, then I can bolt it all back together to test ride and further carb tube.
Old 11th June 2019
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Changed the oil, mounted my water jug that I use for long rides, mounted a cell phone mount on the bars, cleaned up a connection on my XM radio that caused it to go out when it got wet.
John Wayne - "The Shootist"
Old 11th June 2019
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Model #2: FXLR Low Rider
Sportster/Buell Year #2: 2019
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
This weekend I washed both bikes and my Mustang.
Removed the fairing from the sportster, it is looking rough and needs sanding and a repaint, the clear is peeling off from all the bugs this spring.
Today I rode the Sportster to work sans fairing, most likely be going over wet roads and probably through a storm or two this afternoon headed home.
Old 12th June 2019
Saw a disc bolt had backed out on the SuperTrapp muffler, strange, ran it inby hand and found it would just spin, damn. Stripped threads how does that happen running down the road? Had one other that stripped when changed the open cap for a closed one. Checked the rest and another one doesn’t feel good, the others took a little to snug up. Hoping it gets me to the Meet n Greet without issue. Right.....why does this stuff always happen to me?
Old 12th June 2019
Bone's Avatar
Over-tightened cold, expands when hot, strips.
Old 12th June 2019
Well I changed caps over a year ago and probably 20,000 miles, guess it takes a bit of time?
Old 12th June 2019
Lowe175's Avatar
Lowe175 Lowe175 is offline
Lowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really niceLowe175 is just really nice
Began an in depth detailing. Spent 6 hours on it. Probably spend another 6 on it tomorrow. After detailing I'll wheel it out and that should do it.
