0 Currently in deep shift...
Last Post: Lone Rider
0 2003 883R Progressive Fork Springs?
0 Help! VOES And hose
Last Post: unitedcycles
0 Starter under load
Last Post: JonesL
0 what size battery is appropriate?
Last Post: dieselvette
0 derby cover leak
Last Post: shooterj2003
0 Replacing the CV Carb Plastic Fuel Inlet Fitting with a Brass 90 Degree Fitting
0 Changing DNS Servers
0 Helmets Please...
Last Post: rjg883c
0 Slip on muffler
0 Moxley's Sportster
Last Post: Redbeard2
0 Use Force Sportster Exhaust
0 Fuel pump replacement
Last Post: nativebroncofan
0 33mm Front Fork Service-Disassembly
Last Post: 73HEAD
0 09 XL1200C makeover
Last Post: damarble
5 What can cause the engine to suddenly misfire?
Last Post: ezmerf
0 Solenoid rebuild drained battery
Last Post: mikam123
0 Exhaust Wrap
Last Post: TheSterling
0 Photos: King Peanut or Regular Peanut tank?
Last Post: rezchug
epconde (62), floydfan222 (59), Brian (54), Rondall (54), Nightster Man, Scarecrow2311 (50), thatbikerguy (50), SprtyGirl (48), freecdp45 (48), rxr, addy76 (43), sportster883r (39), Steeljester (38), prelude9si (36), 98xl1200s (33), coreyw5306 (31)
One more note of caution...
The two high current contacts (arc shaped) are mounted on the bolt that goes thru the body and on which are mounted the external wires - One wire is from the battery (incoming) and the other wire is to the actual starter motor (outgoing)...
When you tighten the wires onto these bolts IT IS POSSIBLE to (accidentally) rotate those internal contact surfaces and get them out of square with the plunger ring - which will then cause the contact area to be very small - this will cause pitting very quickly as a lot of current is now being funneled thru that small contact area...
If possible, it's best to mount the wires on those high current posts before you close the end of solenoid - This will allow you to press the plunger (by hand) down against those contacts while you tighten the nuts for the wiring... You can also visually see if the contact points are square to the plunger ring...
See the two contacts, each labeled 'B", in the picture at the Sportsterpedia page:
http://sportsterpedia.com/doku.php/t...k:evo:engctl02
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Be careful with that dielectric grease. It does not conduct electricity so you have to be careful where you use it. Use none on electrical connections.
Yes and no, sort of... It is commonly used in plug boots and coil towers. Years ago when I was doing 2-way radio we used it in the antenna connectors to weatherproof them.
On bulb bases:
https://itstillruns.com/apply-dielec...e-5621534.html
Wiki:
https://en.m.wikipedia.org/wiki/Sili...lectric_grease
Sent from my SM-S767VL using Tapatalk
Great info on those links. Wires passing through metal on vibrating machinery are a constant source of problems.
I put a hot-button on this solenoid before installing. It was good to take it apart and see how riding in the rain affected it. I also put silicone grease on and in the rubber boot protecting the high current connection to the starter.
