0 Currently in deep shift...
Last Post: Lone Rider
0 2003 883R Progressive Fork Springs?
0 Help! VOES And hose
Last Post: unitedcycles
0 Starter under load
Last Post: JonesL
0 what size battery is appropriate?
Last Post: dieselvette
0 derby cover leak
Last Post: shooterj2003
0 Replacing the CV Carb Plastic Fuel Inlet Fitting with a Brass 90 Degree Fitting
0 Changing DNS Servers
0 Helmets Please...
Last Post: rjg883c
0 Slip on muffler
0 Moxley's Sportster
Last Post: Redbeard2
0 Use Force Sportster Exhaust
0 Fuel pump replacement
Last Post: nativebroncofan
0 33mm Front Fork Service-Disassembly
Last Post: 73HEAD
0 09 XL1200C makeover
Last Post: damarble
5 What can cause the engine to suddenly misfire?
Last Post: ezmerf
0 Solenoid rebuild drained battery
Last Post: mikam123
0 Exhaust Wrap
Last Post: TheSterling
0 Photos: King Peanut or Regular Peanut tank?
Last Post: rezchug
epconde (62), floydfan222 (59), Brian (54), Rondall (54), Nightster Man, Scarecrow2311 (50), thatbikerguy (50), SprtyGirl (48), freecdp45 (48), rxr, addy76 (43), sportster883r (39), Steeljester (38), prelude9si (36), 98xl1200s (33), coreyw5306 (31)
  #4211
Old 3 Days Ago
Originally Posted by Bigshankhank View Post
I can't help but laugh at the toothpicks that passed for forks back then.
the 6'' extension adds to that appearance.your tubes are what 1-1/2 m.m. larger? not much difference.
Old 3 Days Ago
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1966 Honda Dream 160
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
Those early tubes are 33.4 mm. They used them on the big twin Supergilde too.
Old 3 Days Ago
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
PO swapped mine with later 39mm forks, so more like 6mm difference which counts for a lot when it comes to diameter.
Old 3 Days Ago
those would be from an evo,not an ironhead.
Old 3 Days Ago
Sportster/Buell Year: 96
Other Motorcycle Year: 99
I can't help but laugh at the toothpicks that passed for forks back then. Still, I would buy that.
I want a 60's iron head, but it's not a priority.
Asking $2k OBO with clean title. Runs.
There's enough of the bike there that it would start shaping up once you took some of the junk off.
It's got me wanting to take a look.
1996 XL1200C
Old 1 Day Ago
if the early buddy seat was lonely here's a later one to keep it company.https://reading.craigslist.org/mpo/d...908833884.html I remember when mrmom9r referred to these as the ironing board seat.i can see a resemblance.
Old 6 Hours Ago
Glamazon Glamazon is offline
Senior Master Bike Builder
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
What were they like for comfort?
