0 90" With an HSR45 Setup
0 Speedo ideals
Last Post: dodgetrucken
0 Long intake
0 Who wants to have a ride out
0 Glyptal?
Last Post: Scott
5 What Color Helmet is Most Noticable?
0 Oil lines..
Last Post: Scott
0 Which Battery?
Last Post: Bikeaholic
Last Post: Clevspeed
0 Photo bucket
0 Had Kuryakyn Grips installed
Last Post: RDHenley
0 1995 Sportster 1200, Black/orange, S&S, Supertrapp
Last Post: RDHenley
Last Post: Bigshankhank
1 Pics of pets and what type of animals you have
Last Post: stikflote
0 Ironhead 1000cc 1971 Help with clutch assembly
0 Ironhead Oil Pump Gurus, come inside.
0 Head work
0 More PhotoBucket Horrors...
Last Post: Bob F
0 My 1250 to 1275 build
Last Post: neilp
Old 1st April 2012
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Originally Posted by DaytonaSportster View Post
Nice breadboarding there!
Thanks DS....it is my first go at it but wasn't too bad. Most time consuming part is the layout of the components on the board the first time you are putting it together.
Alright...so a couple more videos to cover all the scenarios the rear light might go through. The first video posted previously is if the brake light is already on and you push the turn signal. As you can see from the above video the DIY module cuts off the brake light and allows the turn signal to flash. After the turn signal is turned off the brake light is allowed to come back on.
Second scenario....turn signal only. If you listen in all the videos you can hear the relay "clicking" when it is being activated and then deactivated:
Third scenario....start with the turn signal and while it is flashing press the rear brake. As you see below there is no change in the turn signal and once the turn signal stops the brake light comes on as designed:
Cosmo
Old 1st April 2012
Ahks Ahks is offline
Sportster/Buell Model: Traded for
Sportster/Buell Year: a
Other Motorcycle Model: Honda CBR F4i
Ahks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura aboutAhks has a spectacular aura about
Subscribing.
Been kicking the idea around converting my 87 to a more modern lighting system.
Old 1st April 2012
Default Brake / Turn (no running light) Module Parts and Price List
I figured I would provide the list for the Brake / Turn Module (no running light on this module). I purchased all these components from Radio Shack. You can probably find these components cheaper...but radio shack is pretty simple to get stuff from.
Components:
(2) 12V Relays Part #275-0248 @ $4.99 ea.
(2) 2N93904 Transistor Part #276-2016 @ $1.99 ea.
(2) 35V Capacitor Part #220MFD @ $1.49 ea.
(4) 1Amp 1N4004 Diode Part #276-1103 @ $1.19 pair
(2) 3Amp Diode Part #276-1141 @ $1.49 pair
(2) 10k Ohm Resistors Part #271-1126 @ $1.19 pack of 5
(2) 330 Ohm Resistors Part #271-1113 @ $1.19 pack of 5
(1) Perf-Board Part # 276-1395 @ $3.19 ea.
Total Cost (minus tax) = $26.38
Old 3rd May 2012
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Great job!
I did something very similar on the breadboard. How would you adapt this to work with LED's?
I think I'm close to finishing my lights/led project. I don't have any way to draw it up though.
Old 3rd May 2012
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
Cosmo, this is way cool, man.
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 4th May 2012
Wilbur, I am guessing you are asking how can I adapt this so you don't have to use a load equalizer with LEDs? What I made will work with LEDs but doesn't do anything to help draw the correct amount of AMPs and prevent the "no flash" or "fast flash" issue. I am not a fan of adding resistors to draw the amps needed as the heat generated can be an issue.
I think there might be some clever alternatives out there. I am investigating that also....although not a top priority at the moment.
Old 4th May 2012
wilbur's Avatar
Wait...What?
Correct Cosmo!
I'm looking for an alternative to the silly power requirement the stock module demands. The leds draw very little power and the obvious fix would be to ditch the module altogether.
I've breadboarded my own led module, but am still tinkering with other ideas. Great write-up on the DIY-B/R/T Module!
Old 4th May 2012
Wil....care to share what LED module components you used?
Some people like the turn signal auto cancel function or the BAS or they want the security system so I am trying to come up with a way to make it work with the current module. I am currently exploring ideas for an amp regulator, if you will, that will draw the correct amps from the module without caring what light is at the other end.
Old 4th May 2012
I've always considered fast blinking turn signals to be a bonus.
Old 5th May 2012
That only happens on 07'+ sportys when running leds (or less smaller watt bulbs). Older sportys the turn signals just fail to flash. However, I agree....I run my LEDs front and rear without a load equalizer and don't mind the faster flashing.
