0 Clutch issue
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 little rock
Last Post: tedg
0 New acquisition
0 brake lever for master cylinder.
0 Ignition question
Last Post: Anti-Hero
5 Summer time heat
0 79 Tranny
0 R.I.P. Arlen Ness
Last Post: oupa
Last Post: moparnut72
0 Have you taken your “dumbass pill” today?
0 883 to 1250 is done
0 883N brake/signal problem
0 I'm going nuts (Adjusting Fuel Mixture)
0 How long for the XL Member patch?
Last Post: bdawson
0 mid controls
Last Post: whetrick1
Last Post: farmall
Last Post: Lone Rider
0 Front cylinder noise
0 900 dual carb front head
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 1200S cam comparisons
Last Post: Saint666
mike, Rick572 (72), Tailchaser (71), Back Road (55), sanman12002003 (54), LilMsRida (54), wargod1 (50), tplyons (32), DOM! (31)
Old 25th November 2016
rocketmangb's Avatar
So that begs the question.
Anybody make an offset crank key so you dont have to move the gear ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Looks good,would like to see one installed though.
never seen the key on the xl, some bt cams could with modification. looking at hammer post, basically the same info I got from a xl build book years back. for street, straight up is the way to go, need boost???slip in stealth nitrous.
http://victorylibrary.com/tech/degree-c.htm
Gets more interesting by the moment ! Thanks Bustert !
Hippysmack's Avatar
I know Hammer has touched on this in the past but is the only correction to move the gear on the #2 Cam
Or am I just making too big a deal of this ?
Well, the #2 cam does turn all the others, so that practice does make perfect sense for adjusting total timing.
Does sound like a big deal and worthy as so. Machine work gets my attention
#2 drives off the crank so if we move the pinion gear it moves all the cams !
My other issue is the small contact area from pinion gear to key.
Seems like a good reason to weld the pump drive and pinion gears together ?
Of course the Bronze pump gear would not tolerate that !
Brainstorming at its best. Gotta love it! Some cool stuff has been formulated on forum pages with sharp posters kicking ideas around.
Joe
Hippysmack's Avatar
Some of our venders need to come up with a clear crank cover for rotation inspection during a build. That would be very helpful while inspecting cam rotation/ positioning.
Hippysmack's Avatar
That settles it then, an assortment of degree'd pinion gears for fine tuning cams. Sounds good to me. The key isn't still called a 'shear key' so theoretically it breaks before the pinion/ crank does? Bad Ju Ju
Be interesting when I get my gear cover back from buddy who is cutting it up !
