Last Post: 2cvandy
5 Jiffy Standing
Last Post: 83XLX
Last Post: 45Brit
Last Post: toe
7 It's Nibelungen's Birthday!
0 brake lever for master cylinder.
0 Modified heads
Last Post: cazz1000
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: cazz1000
0 My Second Sporty A 2012 Forty-Eight
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
5 03 XlH1200 Best top end commination.
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 3rd December 2017
Sprtstr1200s's Avatar
Sprtstr1200s Sprtstr1200s is offline
Sportster/Buell Model: Sportster XL1200s
Sprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond repute
Please keep us posted. A real BUMMER.
rocketmangb's Avatar
What am I not seeing ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Here is the Clutch Diaphragm Spring:
This is the Snap Ring:
Your Middle Picture -
It appears the Snap Ring broke.... Although your last picture of the new clutch install looks like the snap ring is in the right place...
See this thread:
http://xlforum.net/forums/s....php?t=2006082
Was the Diaphragm Spring installed with the fingers out or in?
See the picture at the Sportsterpedia for the 1991-later clutch:
http://sportsterpedia.com/doku.php/t...sign_operation
IXL
2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
A FREE XLForum collection of technical info & advice
Old 4th December 2017
jigoe007 jigoe007 is offline
jigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud ofjigoe007 has much to be proud of
The black piece at the 2 o'clock position is part of the diaphragm spring. I installed it in the same orientation as the stock one I took out.
Do you have any pictures of the clutch with the primary cover removed? That shows all of the clutch pieces after the failure?
Did you have any difficulty compressing the Diaphragm Spring? Did you take a measurement of the stack height when installing the new frictions & steels?
Did you have trouble putting the Snap Ring back in place? Did the Spring Seat come back into place without an issue?
IXL
2 Relax
I'll get back on it this weekend. I only took the inspection cover off. No, it wasn't very difficult getting the clutch installed. I used the Motion Pro compression tool which worked well. I was careful not to over compress the spring. I checked the number of steel plates, friction plates I removed and that checked out with the HD shop manual. The snap ring came out and went in without much problem. This was the original clutch I was replacing so the components haven't been subjected to much handling.
The Barnett should have more total discs than stock no ?
Like 19 ?
Old 5th December 2017
The Barnett extra plate kit replaces the middle HD spring plate that riveted together.
I get that.
Stock is like 17 plus the spring plate
Old 10th December 2017
Default I took the primary cover off..
and the retaining ring fell in the oil below. The Barnett spring looks ok. The retaining ring got loose so how.
I posted some new pictures:
https://imgur.com/a/rChTY
