0 90" With an HSR45 Setup
0 Speedo ideals
Last Post: dodgetrucken
0 Long intake
0 Who wants to have a ride out
0 Glyptal?
Last Post: Scott
5 What Color Helmet is Most Noticable?
0 Oil lines..
Last Post: Scott
0 Which Battery?
Last Post: Bikeaholic
Last Post: Clevspeed
0 Photo bucket
0 Had Kuryakyn Grips installed
Last Post: RDHenley
0 1995 Sportster 1200, Black/orange, S&S, Supertrapp
Last Post: RDHenley
Last Post: Bigshankhank
1 Pics of pets and what type of animals you have
Last Post: stikflote
0 Ironhead 1000cc 1971 Help with clutch assembly
0 Ironhead Oil Pump Gurus, come inside.
0 Head work
0 More PhotoBucket Horrors...
Last Post: Bob F
0 My 1250 to 1275 build
Last Post: neilp
Old 16th January 2018
Sportster/Buell Year: 1991
Wow, can't wait to see how this story ends.
John
mikeLI_77's Avatar
Subscribed.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Subscribed! Wish I had the tools and know how!!
madlim madlim is offline
madlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond repute
Hope the rocker covers dont need to come off !
Thats my second thought as well! First one was "this is just plain awesome"!
Keep it running Keep it running is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1984
Sportster/Buell Model #2: FLHTCUI
Keep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura aboutKeep it running has a spectacular aura about
Me too, me too!
1984 XLS Roadster. Had it long enough I am the PO ;-(
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
That’s bad azz !!!!!
Old 17th January 2018
DM_ANDREAS DM_ANDREAS is offline
Sportster/Buell Model: XL12000
DM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to allDM_ANDREAS is a name known to all
You can't pull the rocker covers off when the engine is mounted to the frame....
BUT...That's not really a problem.
Just take out the two bolts which connect the steering head to the front engine mount. Then the engine can be lowered down, pivoting around the swingarm axle.
No need to disconnect any hoses or cables or anything.
Actually, quite simple and easy to do.
Just put a jack under the engine, take the bolts out and the lower it down as far as required.
Once the complete frame is ready, it's much easier to see how this is going to work.
It's great to hear that you guys like the build so far
Let's do an update...
Here are the finished Axle-Mounts....
Last edited by DM_ANDREAS; 17th January 2018 at 15:50.. Reason: Fixed broked picture links
CyclesInc's Avatar
CyclesInc CyclesInc is offline
Sportster/Buell Model: A Few
Sportster/Buell Year: many
CyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud of
Why does that piston look like an Ironhead piston?
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant future
You are using a rubber mount motor but rigidly mounting the front head to the frame ? There are no front down tubes ? Are you going to use the motor's front rubber mount attached to the frame coming from the rear ?
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
