Last Post: 2cvandy
5 Jiffy Standing
Last Post: 83XLX
Last Post: 45Brit
Last Post: toe
7 It's Nibelungen's Birthday!
0 brake lever for master cylinder.
0 Modified heads
Last Post: cazz1000
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: cazz1000
0 My Second Sporty A 2012 Forty-Eight
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
5 03 XlH1200 Best top end commination.
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 16th October 2018
Toejam503's Avatar
Air-Cooled Forever
Howdy and welcome from North Dakota. Nice bike, great project.
Toro81 Toro81 is offline
Toro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura aboutToro81 has a spectacular aura about
Thank you for comments
Changed the primary gasket today.
The old gasket was really bad, and it leaked alot
New gasket on
Filled with this oil after tightening.
No more leaks from primary now
Tried to clean the K&N filter, but it still looks dirty. So I`ll might try to give it one more round tomorrow
Is it possible to mount forward controls with the Supertrapp exhaust?
Read that it would be trouble
Old 8th December 2018
Some changes since last time.
Tried on another seat,
But I didnt like it, so I put the old one back on
Then I found a LePera seat, and it looked much better
Lower risers
And a new dragbar
ChinCactus's Avatar
Looking good! I have a LePera Silhouette on my 95 and love the look.
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud of
Nice find. If you check the spark plug side of the heads and you see that they are designated "Super Stock" heads, then you probably have had the S&S "74XLSS" kit installed. If so , that package included a specific manifold, 10.5/1 pistons matched to the heads, the Super E carb/air cleaner, adjustable pushrods, travel limiters, and an Andrews N6 cam (S&S 500). If you find out that's the heads you have, I can post a link that will give you more info on them. (They should dyno into the high 80's HP with a good exhaust like you have. Mine is running high 90's with a Woods cam).
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Old 9th December 2018
Thank you.
This is good information. I will check this out later today.
shanneba shanneba is online now
Welcome to the forums from Indiana!
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
