0 Need help with breakin miles
0 Screaming eagle street tuner afr?
Last Post: Tconnor2
Last Post: SLW210
0 what brake master cylinder can I use?
Last Post: just1pepsi
0 super b overflow
0 TC88a DIY Power adapter ?
Last Post: jon1966uk
Last Post: skypeace
Last Post: SLW210
0 The chicken or the egg (bent pushrod)
Last Post: Disturbediwv
0 New Lithium Battery, Lights Go Out
Last Post: Turbo Sporty 48
0 1972 XLCH brake help
Last Post: Imaginearat
0 New LED headlight bulb. Highbeam aim wrong.
Last Post: xena
0 mystery leak
0 Poll: What weight fork oil do you use?
Last Post: jazzman
Last Post: 2cvandy
0 Hi from France
0 Oil pump Iron 1000 1979 bizarre.....
Last Post: jlv
0 Clutch ramp outer
Last Post: 83ironman
0 Xl 1000 1979
Last Post: jlv
0 Why I don't have a HID Headlight Poll
Last Post: SLW210
0 Headlight Modulator
0 Valve to piston contact
Last Post: alaxjordan0
0 New XLH Owner
0 Newbie
rider1951 (68), harveyb (67), 883RRR (65), schnucki (60), sportxl (53), gvd883r (49), ambulldogg (41), Teejay, silversporty86 (33)
Old 9th December 2018
Veeflys Veeflys is offline
Sportster/Buell Model: 883N
Sportster/Buell Year: 2016
Veeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud of
Welcome from Beaver County, PA, Veeflys!
Toro81 Toro81 is offline
Toro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the roughToro81 is a jewel in the rough
Thank you
Originally Posted by RussW View Post
Nice find. If you check the spark plug side of the heads and you see that they are designated "Super Stock" heads, then you probably have had the S&S "74XLSS" kit installed. If so , that package included a specific manifold, 10.5/1 pistons matched to the heads, the Super E carb/air cleaner, adjustable pushrods, travel limiters, and an Andrews N6 cam (S&S 500). If you find out that's the heads you have, I can post a link that will give you more info on them. (They should dyno into the high 80's HP with a good exhaust like you have. Mine is running high 90's with a Woods cam).
Hi. Thank you for good information
Went out and took a picture of it. Is this what you think it is?
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud of
That's them. I purchased a 2002 883/1200 conversion done with this kit, and did lot of digging to find out what was included. It was more popular years ago when the option to modify your stock heads was not so readily available as today. If you check a pushrod and find adjustables, that should be the final clue! The heads weren't always sold as part of the kit, but the kit did include the heads and all the components I mentioned above. If you check your ignition, you will probably fine an upgraded, selectable curve module that enhances this package. Mine had a Dyna 2000i, you could have that or a Screamin Eagle version. These heads are interesting, with 2.000 intakes and a huge combustion chamber which handle a high TDC lift cam. You will find manufacturing numbers on the sides of the heads. A call to S&S and they can tell you the year of manufacture. Earlier versions were set up for cams up to, it think, .560 lift. Later versions (my 2002 set) will handle cams up to .630 lift. What came with the kits were usually Andrews N6 cams with a relatively low .500 lift. Follow the link below for more info. They used the same heads on 3.50" bore Sportsters as the 80" Evo motor. Even back in those days, it was a $2500 package so you got a nice surprise!
http://www.nightrider.com/biketech/d...nder_heads.pdf
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Old 10th December 2018
Sportster/Buell Year: 1991
I love the paint scheme on your bike! Always been a fan of racing stripes, even had them done on my surfboards!
John
Old 2 Weeks Ago
Some new pictures
Old 2 Weeks Ago
Bruce's Avatar
Bruce Bruce is offline
Old Fart M/C Club
Sportster/Buell Model: 883/NRHS 1250 custom
Bruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant future
Looked through the thread, nice buy on the bike. Like the changes you've done. Does it run good?
Ride safe!
Member of "The Cell #2"
Old 2 Weeks Ago
screndname's Avatar
screndname screndname is offline
Sportster/Buell Model: 883c & 07 nightster
Sportster/Buell Model #2: 1200 nightster
screndname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud of
welcome to the forum from usa. nice bike
