0 Ironhead Oil Pump Gurus, come inside.
0 Ramflo air cleaners still available
Last Post: Ted Town
0 Who wants to have a ride out
Last Post: Bob F
0 One sooty spark plug and one completely clean
Last Post: Jonv
0 no spark
0 The general
Last Post: Bob F
0 quick shifters
Last Post: Bob F
3 Recommended IronHead Mechanics
Last Post: DirtyHarry68
0 1960 XLCH in the UK
0 is this a 'Hogged out' 883 head?
0 Mechanic Training/Learning
Last Post: Kbetts
0 520 conversion for ironheads
0 Why my daily speeds are generally slow
Last Post: fafcpa
0 big bore kit
Last Post: Gulf Coaster
12 POLL: How many times have you dropped a motorcycle?
Last Post: duffy
0 signature pic
0 Had Kuryakyn Grips installed
Last Post: Tucsonmax1
buddy (66), paulrainer (66), Pedrochellie, needweknow, BunnMan (48), SolariS (43), Doc69 (39), ftptptt1234 (39), dumbmxer84 (36), nhutch40 (28), XLButler (21), Ztomasc (21)
Old 5th November 2018
Loony's Avatar
Loony Loony is offline
Loony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant futureLoony has a brilliant future
Default Difference in Drive belt width?
Is there any difference in belt width from 2004 sportster to today?
I need a new drive pulley and some odd measurements coming back from sellers.
My 68Tooth 2004 Drive pulley measures 31mm internally between sides.
Regards,
Loony
2004 XL1200 Roadster - TC88A Jester 5. 5 IT - 8 AS (Thanks Rico) - EZ IMS - CVP Jet Needle - 45 pilot - 185 Main - K&N Airfilter - Short Drag Pipes (FMP's) (SEII Slipons OFF)
I was born not knowing and have had only a little time to change that here and there.
Richard Feynman, Letter to Armando Garcia J, December 11, 1985
US educator & physicist (1918 - 1988)
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
As I understand, 2004 -> 2006 used a 1-1/8" belt and 2007+ use a 1" belt. The transmission pulley has not changed, but the rear wheel pulley did change to match the new belt width.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Of course, Dan is right...
Here's the Sportsterpedia section on Drive Belts:
sportsterpedia.com/doku.php/techtalk:evo:transfinal01
You might also want to look at the section titled:
Final Drive Trans Belt Sprocket Issues (Differences between 1991, 1995 & 2004)
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
