0 New to me bike - 2004 1200r -did I miss anything
Last Post: chief100
0 Newbie
0 grinding noise.
4 The no-debate OIL POLL
0 mystery leak
Last Post: 11ccd13
0 New LED headlight bulb. Highbeam aim wrong.
Last Post: Four Speed
0 Oil pump Iron 1000 1979 bizarre.....
Last Post: Bstrdbike
Last Post: joes95bobber
Last Post: walterxlh
0 Could this be an overheating issue?
14 1974 Ironhead sportster xlch
Last Post: Ltdr13
0 71 Iron
0 Street Tracker
Last Post: garyajaz
0 Longer Rear Brake (Foot Brake) Lever?
0 ***DK Custom-*NEW* On Our Site-Scratch & Dent Specials***
0 Dynojet Power Vision 2
0 New member
Last Post: Calcustom
0 Clutch ramp outer
Last Post: Harry
0 ***DK Custom-Beat The Heat-Save 10% on Cooling Components***
0 Rolling Thunder
Last Post: ezmerf
0 Leaky oil drain plug.
Last Post: ezmerf
0 Lake Erie Ride Alums?
Last Post: Shark Doctor
dtw757 (65), XLH75Rider (64), JRLang13 (57), Shaerona (55), christophe (52), collectovince (51), buckethead (41), Hang_Em_High (39)
Old 17th November 2018
rocketmangb's Avatar
Not seeing em Lisa
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
littlelisac littlelisac is offline
Sportster/Buell Model: xl883l
littlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to beholdlittlelisac is a splendid one to behold
I fudge up the pictures on that photo hosting site, I'm going to read the how to a bit more tonight. But good news, I filed down the burrs and tried making it as smooth as possible, I'm turning in for the night because I'm a wimp and I am getting cold(its like 68 degrees) anyways, I tested putting the plates in and I almost fit the entire 9 friction 8 steel plates. I had one left over of each but the first time I tried it I could only get about half that number in so tomorrow I am supposed to borrow a dremmel and it will be light out so I hope to get them all in. I'm excited that I just might fix the problem. Oh and when I went to remove all the plates they all came out with ease, so that's what a clutch basket is suppose to be like! The cynic that I am wonders how I will get the primary back on with the chain tensioner not loosened as well as I never was able to crack that darn clutch adjuster on the cable. Oh I guess I'll cross that bridge when I get there. Another plus was I had been wanting to paint the primary cover so here's my chance with the ol bbq high heat spray paint. Lastly, It's weird when I went to roll back the bike to move the basket(as if I could ever lift the back tire up), the dummy light said I wasn't in neutral yet I was on an incline and was still able to roll back. My light used to always be on when not in gear, is that something I should be concerned over? I know I know get out my service manual. Thanks again
Transmission wasnt hooked to the engine !
harley506d's Avatar
Sportster/Buell Model: 1200c
Is there anyone who lives close (ish) and go help get these nuts/adjusters loose for Lisa?
harley506d's Avatar
My apologies, i should have said put the 2nd spanner (on the jamb nut) at 20-25 minutes to the hour and not past the hour!
rejeanprimeau's Avatar
No plate in the clutch mean natural neutral. It's the clutch that give friction so the engine brake or power the rear wheel.
Old 18th November 2018
Here's a video showing the idea suggested by 'harley506d' --- It is showing two nuts which is equivalent to your adjuster...
Breaking A Double Nut
Also, get yourself a piece of steel tubing (at a hardware store) to put over the end of your socket wrench to use as a cheater bar...
Cheater Bars
It will be important to break loose that Primary Chain Adjuster so you can back it off & properly get the Primary Cover reset in place before tightening it down - Then readjust the tension on the chain using the adjuster & lock it down again...
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
It will also be necessary to get the cable backed off to get the clutch initial adjustment correctly set.
Did you ever post your location littlelisac?
Joe
Old 19th November 2018
shanneba shanneba is offline
Joe
She is in Long Beach, CA. according to her very first post.
http://xlforum.net/forums/showthread.php?t=2071555
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Well I still dont know how to post pics because I'm on my cell phone but today I was able to get all 9 friction and all 8 steel plates in the clutch basket and got the steel plate and diaphragm on there with that damn snap ring holding it all in place. But as for the clutch cable, I noticed that the bolt snapped in half where you connect it to the primary cover so to.orrow morning I'm running to harley to get a new clutch cable and I know how to install that so hopefully the bike will be running. Funny when I got all the plates in the bike is in gear I was able to have someone move it earlier but now I'm in a possible ticket zone, hopefully the parking meter person will let me slide. Parking in downtown long beach sucks. As for that adjuster nut, with a brand new cable I doubt it will be rusted shut. I am worried to what the clutch will be like, as long as it works I won't mind. Thanks again and I will post some before and after photos of the carnage that dumb spring plate did and how to fix it.
Just wait until I decide to upgrade to 883 to become a 1200.
