0 Ironhead Oil Pump Gurus, come inside.
0 Ramflo air cleaners still available
Last Post: Ted Town
0 Who wants to have a ride out
Last Post: Bob F
0 One sooty spark plug and one completely clean
Last Post: Jonv
0 no spark
0 The general
Last Post: Bob F
0 quick shifters
Last Post: Bob F
3 Recommended IronHead Mechanics
Last Post: DirtyHarry68
0 1960 XLCH in the UK
0 is this a 'Hogged out' 883 head?
0 Mechanic Training/Learning
Last Post: Kbetts
0 520 conversion for ironheads
0 Why my daily speeds are generally slow
Last Post: fafcpa
0 big bore kit
Last Post: Gulf Coaster
12 POLL: How many times have you dropped a motorcycle?
Last Post: duffy
0 signature pic
0 Had Kuryakyn Grips installed
Last Post: Tucsonmax1
buddy (66), paulrainer (66), Pedrochellie, needweknow, BunnMan (48), SolariS (43), Doc69 (39), ftptptt1234 (39), dumbmxer84 (36), nhutch40 (28), XLButler (21), Ztomasc (21)
Old 7th January 2019
scooterbe883's Avatar
scooterbe883 scooterbe883 is offline
Sportster/Buell Model: 883c Sportster
Other Motorcycle Model: FLT
Other Motorcycle Year: 1980
scooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to beholdscooterbe883 is a splendid one to behold
ok, got it opened up. I don't see anything out of place. detent plate looks good and clip is in place. I have never heard of a drill bit by a number hence why I was asking...you know like 7/32 or 9/32, etc. I live in a small town and no one had a number 32 bit. I ordered one. I think I'll order a new detent plate and clip. Also, appeared all the drum pins are proper. not sure what else in there will cause what it was doing. since I'm this far, I'm gonna replace the clutch plate with the rivets. see what happens when I get it back together. thanks for the advise so far
Old 8th January 2019
if your plate is good, just a waste of $$$. the clip has a history. shift issues can come from the pawl springs and arms or less likely worn drum, fork pins and forks. be happy, the trap door is easy.
Old 13th January 2019
well, did a check over everything in the primary. very clean and nothing broke. detent plate clean and clip in place. rechecked space with the number 32 drill bit. while in there, removed spring plate and replaced with two steels and a fiber plate. new barnetts clutch cable, adjust primary and clutch, refilled primary with formula 1 and test rode.
