Last Post: 2cvandy
5 Jiffy Standing
Last Post: 83XLX
Last Post: 45Brit
Last Post: toe
7 It's Nibelungen's Birthday!
0 brake lever for master cylinder.
0 Modified heads
Last Post: cazz1000
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: cazz1000
0 My Second Sporty A 2012 Forty-Eight
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
5 03 XlH1200 Best top end commination.
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 9th December 2018
Tom Beckner Tom Beckner is offline
Sportster/Buell Model: XLH 883/HP 1250
Tom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond repute
Default Hyundai/Kia
Anyone familiar with their engine problems in recent years, or with the recent
953 Campaign concerning connecting rod failures?
Thanks,
Tom Beckner
sportsterdoc's Avatar
Tom, what info are you seeking?
The recall that started (restarted from 2015) in 2017 was for some 2011-2014 models, due to machining debris interfering with connecting rod bearings.
No issue with my 2008 Santa Fe 3.3
Old 10th December 2018
doc's Avatar
doc doc is offline
Ice Cream Killer
Sportster/Buell Model: 883/1212
doc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud ofdoc has much to be proud of
We have a 2013 Optima and have had 3 recalls on it. One for the steering knuckle, one for machining debris, and a new one for connecting rod issues which requires a reflash of the ECM (haven't had it done yet). I'm actually impressed with them as we bought our car used from a Ford dealership, but they still send us the recalls and fix and/or check them for free. Unlike Ford, who know their variable valve timing is shit, but won't fix it under warranty.
Doc
'00 883/1212 Custom
Beer is living proof that God loves us and wants us to be happy. - Benjamin Franklin
NOS is like viagra. Impressive? Yes, but once you run out your left limp and inadequate.
Electrical Troubleshooting Tips
My Gallery
Old 11th December 2018
Thanks Jerry and Doc.
From the Hyundai website last week:
Service Campaign 953
ECM and Cluster Update - Engine Monitoring Logic Product Improvement.
Also, on another page:
The software update installs a newly developed Knock Sensor Detection
System (KSDS) that detects vibrations indicating the onset of excessive
connecting rod bearing wear in the engine.
End quoted material.
The ECM then puts the engine in limp mode, and there you are possibly stuck
in the middle of nowhere. I see it as adding a point of failure to the ECM
system, using the knock sensor to add a task it was never designed to do.
Tom Beckner
Limp mode on my 2008 with failing TPS was about 5 MPH...until I restarted the engine, then it was normal...until it did it again; then the TPS was replaced.
Old 12th December 2018
As of a week ago, this was a lock out feature that couldn't be reset.
Since then, the Hyundai web page was changed, and as of yesterday the
page was not available, "under construction" or something like that.
There is an owner's forum, if you can separate the noise from the signal,
and read through all the posts:
https://www.hyundai-forums.com/lf-20...ign-953-a.html
ReddTigger's Avatar
what information are you seeking exactly ??
I might know a guy.
States I've Ridden in
71.3 hp 70.8 tq
Old 13th December 2018
I might know a guy.
Thanks, Anthony.
2015 Hyundai Sante Fe Sport AWD, 2.4L normally aspirated. 62,000 miles.
Oil changes at the dealer since new, nominal 3700 mile interval. Oil type
and specs unknown. They "get it out of a drum", and I gave up asking a long
time ago.
1) Is there a rod bearing problem on this year/model?
2) Have there been any unintended consequences after performing this
953 Campaign modification to the ECM?
So far this has been a great car for us. As a precaution I'm going to send an
oil sample to Blackstone Labs. When checking the oil, there has been no
indication of fuel dilution in terms of feel or smell, for what that's worth.
Tom Beckner
Old 15th December 2018
nice to know they are not far off from nissan as timing chain crapola.
machining debris could cause a restriction to rod bearings. i believe the reflash is to add a protection to prevent you from having a power out in a bad situation. rod knock=reduced power, hummmmm????, what does that help if you need that power to avoid an 80,000# 18 wheeler. i guess the cure is as bad as the problem.
all said and done, i would suppose this damage to be early on in the life of the engine.
