Last Post: 2cvandy
5 Jiffy Standing
Last Post: 83XLX
Last Post: 45Brit
Last Post: toe
7 It's Nibelungen's Birthday!
0 brake lever for master cylinder.
0 Modified heads
Last Post: cazz1000
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: cazz1000
0 My Second Sporty A 2012 Forty-Eight
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
5 03 XlH1200 Best top end commination.
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 17th December 2006
Uncledaddy's Avatar
Uncledaddy Uncledaddy is offline
Uncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud of
Default Are You Insane?
That's about all I've heard so far when I tell people I've just tore my bike down to the frame. My answer... we'll see.
Here is my thought process so far.
Flander's broomstick drag bars: on order
3" risers: on order
Chop/paint rear fender
Internally wire everything
Here is where I could use some experienced advice...
I want to eliminate my speedometer but am worried about how this will effect the communication chain which includes the TSSM and ICM. Does anyone have experience with this?
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
usually i ask before teardown. how about pics of engine mounts and assembly for rubbermount owners? like exploded view pic you see im manual. would be cool to see how they are put together. are you painting/powdercoating frame?
more pics
chrishajer's Avatar
Sportster/Buell Year: 1988
Are you insane?
Looks like fun. I used to strip mine down to the frame like that just to flip the engine over and drain the oil out. Make refilling the primary through the drain hole a lot easier too.
--Chris
You are only if you forget to post pictures of your progress.
melcheld's Avatar
melcheld melcheld is offline
melcheld has disabled reputation
1 question, and 1 opinion:
- What are you planning that required you pull the motor?
- I had the broomstick on my bike for about 2 months. I got rid of it because it put my wrists at an angle that became painful after only a short time. They really make you contort you arm to reach the brake/clutch levers. Just a thought
I don't think you're that insane. I'm interested to hear a more detailed explanation of what you're planning though.
Cheers,
Luke
P.S. I applaud your courage to strip that bike bare
Now if I have suspicion a felony's been committed, I can just walk right in here anytime I feel like it because I've got this badge, I got this gun, and I got the love of Jesus right here in my pretty, green eyes.
Uncledaddy's Avatar
Speedo or no speedo won't effect much besides what wiring I'm going to pull through the backbone. I just want to know if the bike will operate without it. If it won't, I'll just have to get a bracket for my new riser/bar setup.
The mounts surprised me. The book doesn't really do the job justice. I'll get some pics together.
I'm going to be doing some minor frame mods but will only be spot painting with the same (hopefully close) gloss black. I intend on having this thing running again in three weeks (KNOCKING MY HEAD ON WOOD) so a major painting process or any outsourcing is out of the question this time. Again, I will include pics of the mods before and aft.
No Posts
got me thinking of the possibilities.
how about weighing parts. wheres the weight of our bikes come from? why so heavy? hey, its winter. dont think i have anything good to add this time of year
chrishajer's Avatar
OK, I am taking side bets on the three week time frame. Maybe it should be a poll (man would that be cruel.)
I wish you luck, but I also know sh*t happens. It's fun either way though.
--Chris
chrishajer's Avatar
Weigh the frame and swingarm first. Then compare that to a 2003 or earlier. I think that's most of the weight.
--Chris
No Posts
--Chris
if i had a warm work area ide probably be doing the same. i envy UD
