0 90" With an HSR45 Setup
0 Speedo ideals
Last Post: dodgetrucken
0 Long intake
0 Who wants to have a ride out
0 Glyptal?
Last Post: Scott
5 What Color Helmet is Most Noticable?
0 Oil lines..
Last Post: Scott
0 Which Battery?
Last Post: Bikeaholic
Last Post: Clevspeed
0 Photo bucket
0 Had Kuryakyn Grips installed
Last Post: RDHenley
0 1995 Sportster 1200, Black/orange, S&S, Supertrapp
Last Post: RDHenley
Last Post: Bigshankhank
1 Pics of pets and what type of animals you have
Last Post: stikflote
0 Ironhead 1000cc 1971 Help with clutch assembly
0 Ironhead Oil Pump Gurus, come inside.
0 Head work
0 More PhotoBucket Horrors...
Last Post: Bob F
0 My 1250 to 1275 build
Last Post: neilp
Old 11th March 2007
Gone Gone is offline
Banned
Gone is an unknown quantity at this point
Default clutch adjustment
how do i adjust the clutch on my 06 sportster
Old 11th March 2007
Matt Matt is offline
Riding with Angels
Sportster/Buell Year: 1968
Matt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the rough
Get the factory manual and save lots of grief! If you do it you'll know it's right. If somebody else does all you can do is hope.
Matt
Old 11th March 2007
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
I'll be doing mine shortly on my 06, I'll take some pics for you
My Other Toy Goes Mach 25
Old 11th March 2007
cjburr's Avatar
Default Clutch Adjustment
Adjusted my clutch today and took some pics along the way, hope this helps you out. It's a very simple task that will only take a 1/2 hour or less if you have the proper tools.
First thing to do is place the bike upright on a lift so when you remove the clutch inspection cover you don't lose any fluid, if you don't have a lift you need to have someone sit on the bike and hold it upright. The job doesn't take that long so it's not that big of a deal and they don't have to hold it up until you get to the part where you remove the inspection cover.
Remove the left side peg, unless you have forward controls.
Next pop off the spring type retaining clips so you can easily work on the cable.
Pull the rubber boot up to give access to the adjustment on the cable.
Break the jam nut loose and screw it up to the top.
Screw the cable adjuster up against the jam nut.
This will give you lots of slop at the lever like this.
Next remove the clutch inspection cover. These screws take a T27 Torx bit, if you don't have one go to Sears and pick up a kit that has all the Torx bits in it. I was unable to find a T27 by itself and had to get the kit. If you don't use the right bit you will surely strip the screw head and then you have a new can of worms.
Heres the kit I got
Here is the inside, you can see the hex lockplate with the spring attached, if the spring stuck to your cover then the hex lockplate may be sitting there by itself or still attached to the spring, no big deal.
Remove the hex lockplate with the attached spring off of the adjusting screw assembly. You can see how it is slotted to prevent the adjusting screw from backing out.
Using a flat blade screwdriver turn the adjuster counterclockwise until you feel resistance. Then turn it back clockwise a 1/4 turn.
Reinstall the hex lockplate with the spring, turn the adjustment screw clockwise if you have to to line up the flats on the lockplate.
With the bike upright it would be a good time to check the fluid level also before you put the inspection cover back on. The fluid level should be just below the bottom edge of the inspection cover hole with the bike upright.
Reinstall the clutch inspection cover being careful not to dislodge the quadring (rubber seal) from the primary cover. If it comes off use a little bearing grease to hold it in place. Also make sure the spring seats in the cup on the back side of the inspection cover. (See Shu's post below)
Reinstall the screws with some blue LocTite, torquing to 84 to 108 INCH POUNDS
Say it with me now, LocTite is our friend
Adjust your cable by turning the adjuster away from the jam nut until you have 1/16" to 1/8" clearance between the ferrule and the lever housing. Pull the cable away from the housing to determine this. Lock down the jam nut, pull the rubber boot back over it, reinstall the spring clips, put on the peg assembly and you're done.
Unfortunately for me, after my clutch was adjusted properly, I have confirmed that it still slips when a heavy hand is applied at the throttle. So I'll be back with an install of the Barnett extra plate kit soon.
Hope this helps you out, and if you don't have one already, go get the manual. You really need it, at least for the torque specs for your fasteners.
Chris
Old 11th March 2007
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Shu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant future
Great write up Chris. Great pictures. I made it a sticky thread.
One thing to add is that if the spring on the hex plate is not attached, make certain it is not damaged. Also when re-installing the derby cover, make sure you get that spring back in recessed area in the center of the derby cover. Because if it is cocked, it'll snap that sping and the little pieces tend to get stuck in the stator.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 11th March 2007
radar's Avatar
radar radar is offline
Other Motorcycle Model: Road King Classic
radar is on a distinguished roadradar is on a distinguished roadradar is on a distinguished road
Nice writeup Chris!
My Best to all,
Walt.
2005 XL1200C
Black, Chrome, and Taxed
2007 RK Classic
Suede Blue/Black, stock 'till I blow it up
Old 11th March 2007
cjburr's Avatar
Too true Mr. Shu, thank you, I also edited it to tell him to put the bike on a lift so it is upright and he shouldn't lose any fluid when he takes the inspection cover off.
With the bike upright it would be a good time to check the fluid level also. The fluid level should be just below the bottom edge of the inspection cover hole with the bike upright.
Old 11th March 2007
radar's Avatar
Another note: If you don't have a custom derby cover, mark the top screw hole for re-installation, so it won't leak. They sometimes get a little warped to conform to the primary cover.
Old 13th March 2007
Shu's Avatar
Shu Shu is offline
The derby only goes on one way due to the clutch cable hump.
Old 13th March 2007
radar's Avatar
Shu,
You're right, I was thinking of the BT covers.
