Last Post: owlsplace
Last Post: RoadsterMike
Last Post: motorend
Last Post: dieselvette
Last Post: Renecito
0 7 Dead and more wounded
0 Let's See Them R's!!
Last Post: PetesPonies
0 Riding in The Heat!
Last Post: motorend
4 Hello from Chicago
0 What Petcock
0 Efi and carbs
Last Post: Clevspeed
0 45740-62 & 62A differences?
Last Post: Magneto Sportster
0 Stock Seat 48!
0 Fantasy Football League
0 Preston Candover, 23rd June 2019
0 ***DK Custom-4 Stage Vented Billet Catch Can For External Breather Systems***
0 ABS wheel locking?
0 Kickstarter return spring
0 Axle mount license plate bracket question
Last Post: WVDevil
0 WTB - 48 take-off mufflers
Last Post: kent_kurt
0 Tail and turns wiring
0 Newbie from Tennessee
richard rees (70), IRONHD1K (66), derekb (58), Hankrebel (43), CPurner (38), Vickers
rejeanprimeau's Avatar
Silver solder is about 2% silver. Tin is the most important alloy. On a vibrator like we drive tin won't hold steel. Pure silver is a brazing is very solid compared to soldering.
sportysrock's Avatar
sportysrock sportysrock is offline
Sportster/Buell Model: XL883H/1200H
Sportster/Buell Year: '96
Sportster/Buell Model #2: XLCH 1000 w/elec. leg too
Sportster/Buell Year #2: '72
sportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond repute
POR15 Tank sealer works great. It turns into a grey hard coating that is very tough. I got the kit with a cleaner, and rinsed it before drying with a hair dryer. I was nervous about that, but didn't ignite anything. Then applied the coating and swirled it around until it set up.
Sent with :-)
Ol' Big Daddy of the Dirty Ducks MC
I'll see your Twin Cams and raise you 2 more
Unlike the Internet, Al Gore DID INVENT Global Warming
Political Correctness never killed any terrorists.
CMCSSeabee CMCSSeabee is offline
Sportster/Buell Model: xlh chopper
Sportster/Buell Year: 1970
CMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to all
I have used the Caswell epoxy coating in a few tanks with great success. I coated my 1961 BSA Super Rocket tank 18 years ago and it still looks great! It has the damn Midwest ethanol gas in it all of the time too!
never had a liner to work long term. the old tanks were cadmium plated inside.
thing is, liner on liner is like pouring new concrete over old concrete, insured failure as they will not bind together.
the tank outside in the sun is all you need, a day or two and there is no vapor (cap off of coarse!)
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Hey brother...lining won't do anything and neither will solder..especially on a mounting area..itll crack in no time...empty gas, clean tank w hot hot water...a couple times..if ya Have access to a steamer even better or a power washer w sum Zep..then Mig weld it..if ya can't get a mig weld on it then Braze it...just know the tinsle strength is going in that area so low heat on the braze..if your in or near Jersey I would gladly do it for ya...
