0 Hello from Laconia NH!
0 ‘19 H-D Stage-1 models, factory-installed?
Last Post: felis
7 80 Ironhead engine rebuild
0 1966 XLCH in Texas
Last Post: achris03
0 Ran like crap
0 EFI Sniffing.
Last Post: RAIDER0372
0 New from Canary Islands
Last Post: oreocat1
0 What coil(s) do you run with your Dyna S ignition?
Last Post: dodgetrucken
Last Post: tigger
0 77 kickstart shaft.
0 Shovester Sighting
Last Post: chevelle
0 What's your helmet?
0 Exhaust Wrap Questions
Last Post: lmarshall73
Last Post: lynnx
0 Things that Rattle on a Sportster
Last Post: koolbreeze
0 Electrical Problem with '77 XLH-no power
6 New to sportsters
0 Pre lube the rockers?
14 Limey biker
0 C.O.B.B run west
6 Asgardia Regional area
0 2018 Harley Dealer Meeting - Streaming Now
Last Post: O.R. John
0 Any here have experience with B cell Luekemia?
0 Harley Clutch Master Cylinder
13 %~%#~wobble ^!^^#!#^
Last Post: jzink0883
0 Carb
qrtsteve (64), NoRemorse (50), johnboy (49), bmonty72 (46), superscythe (45), grahamc (33)
View Poll Results: What grade gasoline do you use?
Premium Gas 91+ octane 3,622 81.85%
Mid-Grade Gas 89-90 octane 306 6.92%
Regular 87 octane 376 8.50%
I mix it up, don't care, etc. 102 2.31%
Change based on the weather 19 0.43%
Voters: 4425. You may not vote on this poll
  #1691
shanneba shanneba is offline
Originally Posted by Bone View Post
You didn't answer.
What was your question?
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Year #2: 2016
See post 1688.
The answer to your question can be found by reading the link.
Bone's Avatar
No it couldn't. I wasn't at my desktop and the link wasn't working on my phone.
I'll go check it now, but let's go back and cover some basic physics.
There's only so much energy in a gallon of liquid fuel.
If you add oxygenates to increase octane you decrease the total energy.
HOWEVER IF the motor is tuned to take advantage of the octane (the most simple explanation being increased timing to take advantage of the longer burn) you will better utilize the fuel making more power (using more of the potential energy).
IF the motor is NOT tuned for such, you waste it all (which lowers mpg).
So if their studies found better mpg it could only have been in vehicles that were tuned for it (which includes modern autos that self-adjust through knock or ion-sensing or other strategies to advance timing to match fuel content while preventing knock).
Previous studies (and I'm sorry the Canadian television network who did one of the first of these that I saw took the video's down some years back) demonstrated how a vehicle spec'd for regular fuel actually produced slightly higher emissions and lost some mpg when run on premium.
EDIT - so as I suspected, the large PDF study from 2017 only tested vehicles recommended for premium, and even then they found in most cases premium still wasn't worth it. The small/earlier PDF from 2016 specifically said most people at the time (7 out of 10) own vehicles that are spec'd for regular, and one of the main recommendations was to follow the manufacturer's specs.
