0 ‘19 H-D Stage-1 models, factory-installed?
Last Post: felis
7 80 Ironhead engine rebuild
0 1966 XLCH in Texas
Last Post: achris03
0 Ran like crap
0 Hello from Laconia NH!
Last Post: oreocat1
0 EFI Sniffing.
Last Post: RAIDER0372
0 New from Canary Islands
Last Post: oreocat1
0 What coil(s) do you run with your Dyna S ignition?
Last Post: dodgetrucken
Last Post: tigger
0 77 kickstart shaft.
0 Shovester Sighting
Last Post: chevelle
0 What's your helmet?
0 Exhaust Wrap Questions
Last Post: lmarshall73
Last Post: lynnx
0 Things that Rattle on a Sportster
Last Post: koolbreeze
0 Electrical Problem with '77 XLH-no power
6 New to sportsters
0 Pre lube the rockers?
14 Limey biker
0 C.O.B.B run west
6 Asgardia Regional area
0 2018 Harley Dealer Meeting - Streaming Now
Last Post: O.R. John
0 Any here have experience with B cell Luekemia?
0 Harley Clutch Master Cylinder
13 %~%#~wobble ^!^^#!#^
Last Post: jzink0883
0 Carb
qrtsteve (64), NoRemorse (50), johnboy (49), bmonty72 (46), superscythe (45), grahamc (33)
Nightrain Nightrain is offline
Nightrain is an unknown quantity at this point
Default Idle speed
I was reading through my clymer manual tonight and noticed something I think is odd. For idle speed every year listed from 1986-2003 has the correct idle speed somewhere between 950-1050. Except for 1995 us models, which it says 1650-1950! There is also a listing for 1995 HDI models, which is back down @ 1000-1050. It just does not seem right idling that high. Can anyone shed some light on this subject for me? It’s not a big concern, I would just like to have the knowledge.
well, i cannot see your book but there could be confusion between base idle and high idle for ign timing.
base idle @ 30* voes on and 7.5* voes off 950>1050rpm
fast idle @40* voes on and 16* voes off 1750 rpm.
to set fast idle engine is held at 1650>1950 rpm to assure module is at full adv.
street level rpm is still 950>1050 rpm using stock cams. a long duration cam needs more rpm to idle correctly.
I’ll try to post a pic tomorrow
The truth be know those 1995’s had the “unobtanium “ kanuzit valves, a one year experiment, the penny counters got involved and put an end to that!
Oldrump1 Oldrump1 is offline
Sportster/Buell Model: fxr xl1200 5sp
Sportster/Buell Year: 95
Oldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud of
"kanuzit valves"? I have a 95 1200.
Tell me more.
I don't wanna pickle, just wanna ride my motorsickle
Gene
Most info can be gotten from the historians at the MoCo, don’t believe there are any NOS still availible. Might try E-Bay or Amazon?
I suspect that someone spilled 'Clymergoop' on his manual...
I hear that stuff is nasty - changes words unexpectedly & numbers get twisted 'round, too...
I think if you wipe it down with FSM, it probably will help...
2 Relax
come on now, cut some slack. some cannot afford the hd bible.
it is like this:
the girls always look prettier closer to closing time, next morning, not so much!?! hummm, think i'll try again, never know, might find a keeper.
he is trying to find a keeper (info)
Well - May not be the prettiest... but...
https://www.ebay.com/itm/362400086595
Now & then, even the FSM is not 100% accurate...
2 Relax
hummm cheap enough but:
that book is from kentucky and meant for whiskey fueled machines, pretty sure he would need to re-jet.
