Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
6 Calling all musicians
Last Post: FreakyRF
0 Evolution Performance Bolt-On Big Bore Kit
Last Post: jharback
0 TC88a DIY Power adapter ?
Last Post: jon1966uk
0 Scored new to me used tins
Last Post: jharback
0 left him stranded
Last Post: Serious Blac
0 hello from a long time lurker
Last Post: jharback
Last Post: FreakyRF
0 Buying another IH
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
0 Handlebar diameter
Last Post: ironkiwi
0 My 1250 to 1275 build
0 1977 Ironhead big fuel tank options
0 Parts interchange
0 Help ID’ing... Heads and jugs are weird?
Last Post: Bryan1976
0 The Oil Leak Rabbit Hole
0 2004 rear mast cylinder
0 25 April
Last Post: Marcos.Bonfim
0 T bars or Apehangers???
Last Post: spitfirechopper
0 THE Hockey Thread
Last Post: Airbozo
6 73 Sportster Starts, Runs Fine, Dies
0 Locked up rear wheel
0 Just wanted to thank everyone
Last Post: denguy
0 Intermittent Starter
0 78 sportster electric issues
0 S&S Super E jets for 74 XLCH
2 Humble pie
Last Post: mac93
0 Need help with rear brakes for my wide tire project
Last Post: nicktopless
Old 1st August 2015
SeanO's Avatar
SeanO SeanO is offline
Sportster/Buell Model: XLC
SeanO will become famous soon enoughSeanO will become famous soon enoughSeanO will become famous soon enoughSeanO will become famous soon enoughSeanO will become famous soon enoughSeanO will become famous soon enough
Default 90" With Stumble on hard acceleration Mikuni HSR
Moved to Sportster section
2005 1250 XLC, NRHS Stage 2 1/2 Thunderstorm heads, 10.7 to 1 comp., .575 cams, HSR-42, Custom 2 into 1 Pipe. 200mm wheel/tire in stock swingarm.Drag Bars,Home built sissy bar,Custom oil tank, Battery relocation,Coil relocate,Choke relocate and some 1 off parts
Old 14th November 2015
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
For what it is worth, we just completly removed the Accel rod of my HSR42 on my S3 and my WOT stumble is completely GONE, main Jet is a 170
Cycle World Oct 1962:
