Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
0 62 xlch
Last Post: Hopalong48
0 my build in my apartment
Last Post: rickthrash99
0 And so it begins......
Last Post: Texassporty06
0 1965 Ironhead in CT
Last Post: 72 Ironhead XLH
Last Post: Maxdog2
0 Spokes question
Last Post: Scott
0 compression problems
0 Late Ironhead cases interchangeability
0 Mainshaft- What happened here
10 Exhaust Pic thread
Last Post: Nayra
Last Post: Adam76
Last Post: xElvis
Last Post: Nayra
0 Hello from Murcia-SPAIN
0 Shotgun Porn
0 85 clutch adjustment woes
0 Another 2 into 1 thread
Last Post: Scott
0 2-1 Header Pipes
0 1968 xlch
0 Trackday Sportster
Last Post: Tag
Last Post: Tag
Last Post: oupa
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
Last Post: perfesser
0 It's Flame__'s Birthday!
cbsportster (68), sjeccles (51), 2011_Nightster (51), reeb (48), Maff (48), jl_rotary (41), UMLsilva (33)
Old 23rd December 2015
fishman's Avatar
fishman fishman is offline
Sportster/Buell Model: M2
fishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the rough
Today i made the shock mount:
I also ordered 'refurbished" a TC88A from Twin Tec.
Hesitation is not an option!
rejeanprimeau's Avatar
The problems we enconter with fitting a carb on EFI bike is the facking speedometer. Wont accept talking with the TC88A.
fishman's Avatar
Originally Posted by rejeanprimeau View Post
The problems we enconter with f3itting a carb on EFI bike is the facking speedometer. Wont accept talking with the TC88A.
My facking speedo works with a sensor in the front wheel. Ita a Trailtech Vapor.
Old 28th December 2015
69xlch5213 69xlch5213 is offline
Sportster/Buell Year: 1969
69xlch5213 is an unknown quantity at this point
Anything is possible given enough time and money BUT the mounts are entirely different as you may have noticed. The M2 uses the 5 speed XL rear engine mount from the Sportster and the XB uses completely different mounts for the swing arm and the frame isolator at the rear of the XB engine. The M2 uses a separate casting and side isolators.
Send the M2 engine for a performance rebuild with crank truing and rebalancing- sell the XB 12 parts to a guy with an XB frame.
The XB engine is a completely different crankcase.
fishman's Avatar
Rebuilding the M2 engine costs way more and i like a challange....
Old 6th January 2016
fishman's Avatar
Made a motormount:
Next problem is the wheelaxle. XB is 30mm, M2 is 25mm.
I'm confused, Why can't you just use a wheel and axle from an XB?
Absolutely solid result and my appreciation for the images. As you know people's plans often require skills they, themselves do not have though in this case you have been doing great work and have a real tribute to yourself and your teachers.
On a side note I was studying XR1200X racing setups developed by Vance and Hines and they machined spacers to replace the rubber dampers on the 1200X frames and swing arms. Completely different bike but something to consider.
fishman's Avatar
I'd like to keep my M2 wheel. XB wheel is the last option. They are very expensive over here...
ah now I understand. I think you should be able to change the bearings in your M2 wheel to 30mm ID and get an XB axle to solve the problem.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
