0 Have I got my cam gears lined up right?
Last Post: Tyler Lillie
0 Howdy from Baytown, TX
Last Post: 02Custom
0 Who's still riding???
Last Post: dodgetrucken
0 Seat Poll - Bad Ass or Fat Ass
0 Memphis Shades Rio Grande & Trigger Lock
Last Post: jswhite
0 Mixture screw has no effect. Need help!
0 How stock is your bike
Last Post: SLW210
6 Is Your SPORTSTER...
Last Post: Sportycus
5 Your stomping grounds
0 To lay it down or not?
0 How many amps does a 2003 XB charging system create?
0 Spokes and dual disc
Last Post: PetesPonies
0 IronHead Wire Diagrams Etc
Last Post: rubine
Last Post: Jollly Rogers
Last Post: ed_in_az
0 When Were You Born?
Last Post: MacSporty02
0 Cracked exhaust bracket short shots
Last Post: newroadster
0 Early/Late 73 case date code
0 seat bolt
0 Gravydog crashed again.
Last Post: gravydog
Last Post: rubine
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Straight 1" risers on 1200c
Last Post: chain
Hughieboy's Avatar
Hughieboy Hughieboy is offline
Sportster/Buell Model: XL1200X 48
Other Motorcycle Model: Lambretta Li150
Other Motorcycle Year: 1962
Hughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to allHughieboy is a name known to all
Given that observation, I would say you should do what I always do when tracking something down like this. Every bodged up thing you come across, you fix right then before you move on to the next thing. Get it all right as you go, then it won't be a temporary fix, it will last for years and give you some trouble free riding.
Don't get frustrated, there is a problem, and you have a finite area that the problem is inside of. You will find it.
Thanks. To be honest, I need to replace the entire loom/harness. But I want to get everything working first and then replace parts as needed. Only had it 6 weeks and haven't managed to get it running right yet. You're right of course, I will find and fix this before moving on.
rejeanprimeau's Avatar
First place to look is the wires bunch going out the handle bar switch housing, often get pinch and cause inter wires problem
wedge's Avatar
wedge wedge is offline
Very true.
Hughieboy's Avatar
Default Front brake shorting?
So I finally found the issue and fixed it. After changing earth straps, doing continuity tests, repeatedly stripping and checking the wires behind the headlamp, the wires around the circuit breakers and the handlebar switch assembly and also the ignition which has taken me the best of a week an hour or so a day..... I traced it to the back brake switch! The red wire was bare where it had been rubbing on the actuator tab where someone had fitted it on crappily and then wrapped the wires in Sellotape! So it was grounding on the frame and tripping the circuit breaker when you pull the front brake and overload the circuit I guess. I didn't check it because the rear brake operated the brake light just fine!
Half an hour with a small wire brush and some heat shrink wrap and the job is done. Wish I'd checked the obvious first but I now have the benefit of a good working knowledge of XLCH electrics!
sltm1 sltm1 is offline
Sportster/Buell Model: Roadster XLS 1000
Sportster/Buell Year: 1979
sltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud of
Mine were shorting at the handlebar electrical housing, I took them off the switch and folded them back sealed & with shrink wrap....knowing the front light doesn't work reminds me to use my rear brake as well as my front everytime I brake. I've had to pull that housing apart 3 times so far (front master cylinder, kill switch and start switch) so I'll play with it at a later date.
doodah man's Avatar
Originally Posted by Hughieboy View Post
...someone had fitted it on crappily and then wrapped the wires in Sellotape!...
the goofy things po's do; it never fails to amaze!!
Hughieboy's Avatar
It makes you wonder.... some of the half assed workarounds must have been more difficult to do than to do the job properly in the first place!
