0 Topend problem
Last Post: dodgetrucken
5 Favourite grips?
0 Anyone try the new Conti tour tires
Last Post: Airbozo
0 '71 XLCH starting issues, any ideas?
Last Post: echale3
0 First Harley(has issues) - 95 sportster 1200
Last Post: Airbozo
0 ***DK Custom-Announcing The 5th Annual Internet Bike Contest***
0 Front brake shorting?
Last Post: The Doctor71
0 35mm Kayaba Fork Disassemble
0 Another spark plug question...
0 Another ironhead roadracer
0 03 xlh 88"
Last Post: conv90
Last Post: newroadster
0 Sportster tachometer wiring question
Last Post: sleighcrane
Last Post: spitfirechopper
0 MikuniHSR REAL WORLD tuning tips for beginners
Last Post: conv90
0 hi guys kiwi from australia...we make more money over here
Last Post: khav
0 1974 manifold seal clamps question
0 Gravydog crashed again.
0 Rumble strips
9 Aftermarket Petcocks
Last Post: sportysrock
Last Post: Sportycus
Last Post: Jollly Rogers
Last Post: vspkent
Dead Henry (71), iustabfast (64), dcinpa (62), jwursta (62), G-TIFF (60), TexasHarley (60), CROW (58), Darrell (57), dotom, H34TH3N (56), TessArooo
Old 6 Days Ago
DP CUSTOMS DP CUSTOMS is offline
DP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really niceDP CUSTOMS is just really nice
Default Sportster Ironhead Alternator Conversion issue
Hello, I'm hoping someone can help!
I installed a new alternator conversion kit (V-Twin brand) on a '79 Ironhead. At idle, the voltage is around 12v and at full rev's it's maxed at about 13.4 volts. After enough riding, the battery will eventually get too low to start the bike.
The bike is all new. New lithium battery, new wires, etc.
Has anyone had this issue with one of these kits? It's charging a little bit but not enough. I'm used to seeing over 14 volts on other bikes. This one is stripped down, with only a headlight & tail light. Regulator has a good ground.
Thanks!
Old 6 Days Ago
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
What lithium battery? Some of them require special charging regulators as they don't process the same way a lead acid battery does.
Beyond that, 13.4V at full revs is pretty low. I would agree that you should see 14V+ at that rpm. Even my CE DGV-5000 generator runs 13.7V+ at 2000rpm.
Old 6 Days Ago
Thanks, it's a Ballistic lithium battery. I've run Ballistic's many times on Sportster Evo's with no issues, however, that's using stock modern Evo regulators & stators. I hoped this alternator/regulator kit would work the same way (V-Twin part # 32-0372). I've seen other posts where people have had over 14v with their kits and they work well. Maybe I got a faulty alt or reg.. or both?
Old 5 Days Ago
http://www.enerdrive.com.au/can-char...-acid-charger/
a tad info
https://ricksmotorsportelectrics.com...fierregulator/
Old 5 Days Ago
Scuba10jdl's Avatar
I would want to check the alternator output. It honestly sounds like it is kind of weak.
Old 4 Days Ago
Thanks. I checked the A/C voltage from the 2 alternator wires (unplugged from the reg) and it's making power. The higher the rpm, the more volts ( from the teens up to mid 40's, almost 50 if I remember correctly). So, I guess the alt is good. With the reg plugged back in, it does seem to charge a little but not a lot. Battery is around 13.2 resting, and the highest I got it to today was 13.4v revving the crap out of it. This just seems too low, again, I'm used to seeing over 14v on other bikes. If the regulator is bad, would it completely fail or is it possible to still send out some 'low voltage?'
