Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sportster Motorcycle Custom Finishing
0 New member
Last Post: trucker2800
Last Post: staniel
0 XR1000 streettracker project
Last Post: CT XR rider
0 F/S 01 Sportster 883, semi cafe style
Last Post: Truckedup
0 New to 2002 hugger 883
Last Post: Kedge
0 Pictures that need no explanation... don't let this thread die!!
Last Post: 4schizzle
0 1999 Buell X1 Part out
0 handlebars
Last Post: motorend
0 Wet Sump Ifo, fix and tools
Last Post: smokey 2
0 A Day in the Life...
0 XLCH Crazy voltage spike
0 BETTER Brakes for $214
0 oops, my bad.
Last Post: lostNdallas
0 Front forks replace or restore
0 Flame's New 1989
Papatony, chedd (74), Nevar (69), nrbase (67), Smokin-Smitty (62), kbfarkas (60), Irondreads (50), Tim97509 (49), CCM0021 (48), wandrur, bikerusn5 (36)
  #71
Old 10th April 2016
Rabs's Avatar
Rabs Rabs is offline
Sportster/Buell Model: 883R
Rabs is an unknown quantity at this point
Just finished installing my new layback riser speedo mount solution!
Bought an aftermarket mount that matches the original, cut it up and welded it back together with the cylinder at 90 degrees to the bracket. Painted in wrinkle black to match the stock one.
I'm dead pleased with it - pics to follow!
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
I went with a couple pieces of steel tubing and longer screws into the headlight brow holes. A little filing for clearance and the holes lined up nicely.
With 3.5" risers I wanted the speedo off the clamp.
twohawks's Avatar
twohawks twohawks is offline
Sportster/Buell Model: 1200 Custom, 883 Brat, ++
Sportster/Buell Model #2: Hugger
Sportster/Buell Year #2: 1995
Other Motorcycle Model: Jeep Grand Wagoneer
Other Motorcycle Year: 85
twohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura abouttwohawks has a spectacular aura about
Got a pic?
(Still have not mounted mine.)
Nevada Sierras
On Road - Harley. °`°º~_ò^\o_/|\_†
'88 FXLR, '95 Sportster 883, '96 Sportster 1200c, '18 FLHCS
Off Road - |_\o||||o/_|
. 85-90 CJ/FSJs
Here's a shot of the mount. I held the speedo up to get an idea on the tube length then cut it. Then measured how long a screw I needed.
I like it as is, it cleans up the handlebars and lowers the speedo to a less obnoxious height.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
I used short spacers, 1/2” thick, with rubber washers on either side of the speedo/tach bracket.
Sleepy Labeef rides again!
twohawks's Avatar
Cool , thanks Helbent4, and Maxeffort. I've been lazy this year. I did not get to wrenching on my Sporty this year -been playin on my other rides (with what little time I been able to scrape up this year).
I have a Baron Custom Accessories Mini-Bullet Tachometer w/Black Face - BA-7573-01 I need to install on the (95) Sporty. (that link is just for pic, I didn't buy it there)
I put a 48 front end on it 2-3 years back, including the headlight (and utilizing the old housing! [was kind of a feat -for me anyway]). I never got around to writing up and posting the whole affair (although I did document everything so I could). I also customized the front wheel rim for running tubeless tire ;^)
Wandering a bit off-topic ...here's a pic...
...Oh, wait, that's the "ghost front end" :devilgrin:...
Here's the upgrade....
Stock (acqusition). The ugly duckling...
48 Front End I picked up. Included Headlamp, Axel + Spacers, Stablizer, Risers, and Brake!...
The dealeo....
Notables:
- upgraded headlight assembly installed into stock headlamp housing ::grin::
- I kept the old-school brow and speedo mount assemblies
- I picked up a/the long style front fender and installed the stock mud-flap hardware on it.
- I modified the bars a little (thats why they appear orangish -from the torch [still gotta clean that up])
- unfortunately could not use the new risers -another day for that.
One day I gotta post it up.
Happy Trails.
