Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Project
Last Post: rurlndum
0 WTB: Factory Ironhead 2-1 Head Pipes
Last Post: wrkdWS6
0 timing troubles!
Last Post: 72 Ironhead XLH
4 Grinding noise when revving up
Last Post: christophoro
Last Post: longride
0 Is this 1200R worth $4500?
14 DEAR Harley Davidson,
Last Post: awilson40
0 Winter Storm Warning
4 The no-debate OIL POLL
0 Celebrating Sportsterpedia's Third Anniversary
0 68 xlch wiring
Last Post: Zach68
0 joyride memories xlx ironhead
Last Post: Sportycus
0 Mustang's new seat? Anyone tried it?
0 Photos: King Peanut or Regular Peanut tank?
Last Post: Calcustom
0 XL883L 2006 coughing and backfiring
Last Post: Bama Lee XLC
0 How many helmets?
0 Clutch Spring plate poll
Last Post: bimbo
Last Post: JKKO
0 1981 basket- restomod questions
Last Post: 1977iron
steve yorke (61), edman (53), Hudsonator (51), kozman32 (51), R3DN3X (49), gmcsid (48), mitch (43), Gotenfan (29)
Old 11th August 2014
purpony's Avatar
purpony purpony is offline
Sportster/Buell Model: Buell X1 Lightning
purpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to behold
Bike is complete- Just took it for a test ride!!
lugster's Avatar
lugster lugster is offline
Sportster/Buell Model: xl883r
lugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond repute
Great job! Congratulations on your build.
Old 18th October 2014
buellbobster buellbobster is offline
Sportster/Buell Model: xb12ss
Other Motorcycle Model: Honda nx250
Other Motorcycle Year: 1989
buellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the roughbuellbobster is a jewel in the rough
Hey man sweet job, front to rear. I'm really digging the v-rod headlight on the xb forks, fits the look right. Probably gunna have to borrow that idea from ya for my rigid xb chop.
Actually, would you be interested in selling me a set of those custom headlight brackets you made?
Old 6th July 2015
purpony's Avatar
Still modding, more and more each year. Here are the latest pics of my build.
Current updates include-
-billet switch housings
-new switches
-new wiring run in the handlebars
-Brembo RCS 19mm front brake master
-Brembo RCS 16mm front clutch master
-Billet levers for front masters
-Rizoma billet clutch reservoir
-Billet front reservoir mounts
-Random Engineering hydraulic slave cylinder/billet derby cover
-HEL clutch hose
-EBR front rotor
-EBR front rotor hardware
-Braking rear rotor
-4 piston Brembo rear caliper
-Billet rear caliper bracket
-Billet rear wheel spacers
-HEL front and rear brake lines
-Billet rearsets
-Billet shifter
-Billet brake pedal
-Woodcraft toe pegs
-LSL billet pegs
-Billet fixed peg mounts
-Alpina tubeless XB wheels
-Michelin Road Pilot 2 tires
-Motion Pro REV2 variable throttle
-Driven hand grips
-CRG 2" mirrors
-Seat cowl
-EBR american flag decals
-Black tank letters
-Re-painted tank
-Updated 07+ oil pump
and probably a few other things i forgot.......
Old 25th July 2015
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Your bike is just plain awesome.
Old 19th January 2017
purpony's Avatar
wow... i have not been on in a while....
always updating my bike though.
re-did the entire front end and electrical system.
Swapped the bike over to Buell 1125 CR forks and am now using my own designed and machined Billet triple trees. These trees incorporate a GRP radial steering damper tucked under the handlebars with a custom frame mount. Risers are my own design and have passages with removable inner plates for all the wiring to run. All wiring is in the handlebar. Top bar clamp houses 3 buttons, indicator lights, and my motogadget miniscope speed. The bike has been completely rewired using a motogadget M-unit, m-lock wireless ignition, m-buttons housed in my own designed and machined housings, and a m-button inside the fatbars. Also running a Buell "Prototype" Billet ZTL2 front caliper, Aluminum oil tank, and Billet headlight housing with a JWSpeaker LED insert.
Old 1st February 2017
Flame__'s Avatar
Flame__ Flame__ is offline
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2000
Sweeeeeeeet
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 27th August 2017
Lucky13zk Lucky13zk is offline
Sportster/Buell Model: X1 Lightning
Lucky13zk is an unknown quantity at this point
That's an awesome looking Buell you got there. Has to be the coolest one I've ever seen.
What did you do to secure your gas tank and panel inserts on the front? I have a 99 also and I've always just zip tied it down but yours looks like it's all nicely screwed into place. How would I go about doing such a thing?
Old 28th August 2017
Your vision, in all its formats has been a joy to follow, and I suspect that there just might be more in the works. Kudos to you and your fab skills, thank you sir.
Old 27th October 2017
jakebarrell jakebarrell is offline
Sportster/Buell Model: XL
jakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to alljakebarrell is a name known to all
You have no doubt done an excellent job on this one! It looks real neat! What are the upgrades you have fitted?
