0 Hi from the UK
Last Post: oreocat1
0 Question of the month?!
Last Post: The Doctor71
0 Magnaflow F-Bomb on a Rigid?
0 Keith Black Conversion
Last Post: hexnut
Last Post: jordan1200
0 nine T racer
Last Post: conv90
Last Post: Mad Max
Last Post: RKN
0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
Last Post: Sportycus
5 Eye Protection When Riding?
0 Gravydog crashed again.
0 What color are your pipes?
0 Relocated Turn Signals
Last Post: 1Scooter
3 Shaky Dave Recovery
0 With this fit my 99
0 1200s mid throttle stumble
Last Post: NZstu
Last Post: Kejobe
Last Post: Screw Loose Dan
Last Post: Rodzilla
Old 20th June 2018
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Year: 1974
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
My take would be there wasn't a good cross hatch hone on cyl walls to hold oil.Also may have been from cold start ups .
Murphy's Law :vvet:
Old 20th June 2018
I think it is lack of oil because the damage is on the thrust side of the piston.
Other piston is probably scuffed on the thrust (rear) side as well
Hot Idle speed on an Ironhead is 950, cold is higher ~1500 rpm.
Or perhaps no oil? or no oil feed?
The piston pictured does not appear to be very old.
Old 20th June 2018
Gold Member's Avatar
Sportster/Buell Year: 1972
I just looked them up, they are Wiseco forged pistons. No I wasn't there when they were put in and know nothing about them, but I will say I'm ticked okay no bullshit that they are virtually new and yet wrecked.
I do believe the cylinders are able to be cleaned up...I don't think I noticed any cross hatching...I think I will hone them...
My best guess is air leak at the manifold...I think Shaky Dave is probably right but before it goes back together the bore should be measured at a machine shop and I will know more...I'm fixing the case crack before I deal with the cylinders so this problem will go on the shelf until then...
I'm really pissed about those pistons being destroyed...
Old 20th June 2018
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to behold
+1 on the cold starts.
Old 20th June 2018
several issues
rich mixture and cyl wall wash off
lean mixture and heat
not enough cooling
wrong oil
when you pulled the heads, oil drains to skirt open (head gasket), should be no issue at +.020 but as you bore, the skirt holes rise and if you have a crappy rifle drill, could allow the skirt to block good drain back. very rare but have seen the holes that needed tapering downward.
oil is the cooling agent here if blocked, oil goes to p/r tubes.
lack of lubrication
wrong initial fit, expansion
Old 20th June 2018
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1992 Honda xlr250r
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of lightdavixlrtt is a glorious beacon of light
My best guess is overheated, either new pistons not given enough clearance or someone didn’t give them enough break in time before twisting the wick. Either way, the pistons expanded to the point where clearance disappeared.
......Davi.
Old 20th June 2018
spacecoast spacecoast is online now
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to behold
......Davi.
My thinking as well.
Did he use wisecos clearances or oem?
Old 21st June 2018
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
I would have to say they look like lack of clearance, being forged they will swell a ton more, especially that being the front cylinder makes sense since it runs the hottest.
I have done that exact same thing when I put my stroker together S&S told me to clearance them 3-5 and they tried locking down. I ended up clearance at .007 after destroying 2 sets of pistons.
Just take your time it will all come together.
Old 21st June 2018
Cold cyls.
Warm right wrist.
Old 22nd June 2018
If the pistons were too tight the damage would be equal on the front and back side.
Damage like that could be caused by an extended idle at low RPM.
It sounds really cool to let it sit there in the driveway chugging away potato potato potato.
But that is the sound of your pistons being ruined...
