0 Hi from the UK
Last Post: oreocat1
0 Question of the month?!
Last Post: The Doctor71
0 Magnaflow F-Bomb on a Rigid?
0 Keith Black Conversion
Last Post: hexnut
Last Post: jordan1200
0 nine T racer
Last Post: conv90
Last Post: Mad Max
Last Post: RKN
0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
Last Post: Sportycus
5 Eye Protection When Riding?
0 Gravydog crashed again.
0 What color are your pipes?
0 Relocated Turn Signals
Last Post: 1Scooter
3 Shaky Dave Recovery
0 With this fit my 99
0 1200s mid throttle stumble
Last Post: NZstu
Last Post: Kejobe
Last Post: Screw Loose Dan
Last Post: Rodzilla
Old 12th July 2018
sportysrock's Avatar
sportysrock sportysrock is offline
Sportster/Buell Model: XL883H/1200H
Sportster/Buell Year: '96
Sportster/Buell Model #2: XLCH 1000 w/elec. leg too
Sportster/Buell Year #2: '72
sportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond repute
Default Nicked Stator Repair?
While changing primary lube, I found a piece of rotor magnet stuck in the drain plug hole so I got a newer model 8 bolt rotor/front sprocket. Upon disassembly I see one of the stator coils is nicked right on the front, but not through, so easy to get at. A new rotor was the right choice. Parts of it were crumbling. I got some bits out of the bottom of the primary that were stuck to the gear selector spring.
Placing my ohmmeter across the stator wires I don't get much of a reading, but I am pretty sure this has been charging or my battery would be dead.
So my question is, should I try solder gun and a bit of solder in the spot, or button it up and see what the voltage reading is while running?
Ol' Big Daddy of the Dirty Ducks MC
I'll see your Twin Cams and raise you 2 more
Unlike the Internet, Al Gore DID INVENT Global Warming
Political Correctness never killed any terrorists.
Old 12th July 2018
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
No don't solder it. If it is just nicked and the wire isn't damaged, I would put some exoxy on it to seal.
Now what reading do you get? You want to measure in ohms and it should be low. Check here for details.
http://sportsterpedia.com/doku.php/techtalk:evo:elec02
Make sure the stator is not grounded also.
But for the extra $65 you might just replace it.
So why I say do not solder is this.
It will take a lot of heat to really get the solder to stick (if it does at all) and heat will most likely distroy the stator windings.
Old 12th July 2018
is it just the varnish that is off or is there damage to the wire itself??
as mr. dceman said, heat can cause other issues. the insulating varnish is very tough and it will require mechanical abrasion to feather it back enough to get a good solder joint. they do have very low temp solder that can work and you can go to an electric shop and get a can of insulating varnish to cover it over but the stator must squeaky clean. if you apply too much heat, the varnish can break down and you will get a winding to winding short which effectively kills the output of the coil. since the hd unit is series wound it will show up in the final output as hash and probably knock down the voltage a tad, to the point of no charge, good ?.
Old 12th July 2018
I didn't write down what the ohm reading was. Almost non-existent though.
There is a nice little chunk taken out, and it appears not to be broken completely.
So, if there's a break the whole thing is toast, or repairable by jumpering over this set of windings?
Just thinking out of the box. Thanks.
There is an excellent local starter/alternator repair shop in Lebanon, NH. called Dave's Starter & Alternator.
Sent with :-)
Old 12th July 2018
unless you wind it yourself, not worth the cost for a shop to do it or repair it. you will not be able to by-pass the winding for two reasons
1. series wound, if you remove it, resistance is lower and current is higher, the hd unit is borderline anyway and would burn out.
2. there is a N/S relationship between the pole piece and magnet and this is reflected in the sine wave produced and removing it will screw the clean sine wave up and alter the time relationship. your system is a 12 pole ac alternator, remove one pole, see what i mean. also, voltage/amperage output would go down, enough to hurt, good ?
pig in hand, giver'r a shot and let us know.
Old 12th July 2018
I'll try to run it, and see what output is. Thank you for the tips. Kept me from screwing the pooch, because it turns out the pups wouldn't be pretty.
Sent with :-)
Old 21st July 2018
Update: I finally got the primary side together, and adjusted. The alternator output is roughly 14.08 at slow idle and 14.2 at light throttle. We have a Winner! The stator was saved from destruction but the disintegrating rotor magnets. One thing I didn't check was the # of front sprocket teeth. This started as a '96 883, and the sprocket/rotor is off a 2003 I think - but not sure if it was an 883 or 1200. Maybe they're all the same, but IDK right now. It's the newer 8 bolt design too.
Sent with :-)
