Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Cafe Racer Sportster Motorcycle Talk
0 WTF Happened
Last Post: barefoot
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
0 Throttle Cable Install Problem
Last Post: Turbo Sporty 48
0 Cylinder Piston kits
Last Post: Dave L
Last Post: jordan1200
0 05 and 73
0 What is this?? 07 efi 1200 weird box
Last Post: Hank21113
0 Brake light stays on
Last Post: jammantoo
0 S&S Stealth
Last Post: lucifer_mr2
0 Front brake won't bleed 1989 sportster
0 Not charging issue!
Last Post: tvon
0 HAMMERPerf 90" In the Works
0 Crusty Curmudgeon’s Sportster Dictionary
Last Post: barefoot
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Last Post: brianbbs67
0 Tool Roll Help
Last Post: ReddTigger
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
0 Back in Sporty Land
Last Post: skien
Last Post: The Crusher
Old 11th February 2011
ironphuc's Avatar
ironphuc ironphuc is offline
Sportster/Buell Model: XL883R conv.1250
ironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of lightironphuc is a glorious beacon of light
Default Speedo in headlight bucket & microtach install
First cut the indicator lights off of the stock speedo bracket and cut the excess from above the lights. Then made a piece to weld to it to put the microtach in that would fill the recess in the top triple tree. Added a cover piece across the front to hide the wires. Welded a couple studs underneath to bolt the tach up with. A little filler and paint and voila!
Then cut the sleeve (remainder of the stock bracket) for the speedo to the right height and matched it to the contour of the headlight bucket (7" EMGO). To help match the shape of the bucket I wrapped a thin piece of cardboard around the sleeve, taped it and hacked on that till it matched. Then traced that onto the sleeve and cut it with a dremel with a cutting wheel. Took some filing and sanding to get it to sit right, but wasn't to bad. Eyeballed a centerline on the bucket traced the sleeve and cut out the hole. Had a co-worker TIG the two pieces together. Blended it all together with some filler then rattled canned it with Harley texture black. Relocated the odometer reset set button just below the ignition switch that I previously tucked into the neck gusset. Also gave the trim ring on the speedo a quick polishing job. The speedo is a pretty snug fit, just used some black silicone to hold it in place. If the that fails I'll make a bracket that will use the headlight mounting bolts and the 2 screws on the bottom of the speedo that originally held the bottom cover on.
Sorry I didn't think to take a picture of the bucket and cut down sleeve before it was welded and blended.
My first experience at bondo, took forever to get it to blend smoothly and not show any lines.
Before
During
After
Now I'm just waiting for the weather to break enough to clean up the roads so I can go ride.
I know, still need to paint the rear fender after chopping it. One of these days.
dewiz1's Avatar
dewiz1 dewiz1 is offline
Sportster/Buell Model: xlc883
dewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the roughdewiz1 is a jewel in the rough
Looks neat, wonder though what effect the heat from the bulb will have on the speedo?
other than that its nicer.
HellHammer132's Avatar
HellHammer132 HellHammer132 is offline
Sportster/Buell Model: 883C
Sportster/Buell Model #2: 883H Led Sled Hardtail
HellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to all
Nice work! I think it would better if the speedo were more sculpted into the headlight bucket at an angle. Fit and finish looks very good!
eff snow
ironphuc's Avatar
I did think about the heat issue, will just have to keep an eye on it.
zenfrogmaster's Avatar
zenfrogmaster zenfrogmaster is offline
Sportster/Buell Model: Buell Cyclone M2
Sportster/Buell Model #2: Cafe Sportster
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 883 Sportster
Other Motorcycle Year: 2002
zenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished roadzenfrogmaster is on a distinguished road
That looks awesome - great job, very creative.
Old 12th February 2011
flskevin's Avatar
flskevin flskevin is offline
Be annoyed Now;Ask Me How
Sportster/Buell Model: 1200XL Custom
Other Motorcycle Model: FLSTC Heritage Softail
Other Motorcycle Year: 2008
flskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant future
Talk about cleaning up the bike. It looks great! It's almost scary when a Sporty Rider with some skills starts using his imagination...
That would cost a lot of scratch to have something like that done.
"... With Liberty & Justice for All." Must be 18, Void where prohibited, Some restrictions may apply, Not available in all 50 states.
Pastafarian Minister - Church of the Flying Spaghetti Monster
Dudeist Priest - Church of the Latter Day Dude
bridgerholt's Avatar
bridgerholt bridgerholt is offline
bridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the roughbridgerholt is a jewel in the rough
That is Fu*ckin sweet!
SuicideCharley's Avatar
SuicideCharley SuicideCharley is offline
Bike Builder
SuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to all
Dude, that is the sickest speedo mod I've ever seen! I have a similar headlight and just may attempt your mod.....awesome job man.
Buellbomb Buellbomb is offline
Sportster/Buell Model #2: DualSportster 883
Sportster/Buell Year #2: 1994
Other Motorcycle Model: Ducati 1098
Buellbomb has disabled reputation
Great job!
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is offline
Sportster/Buell Model: XL1200c
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
Now that is Hot Rodding!!! Your set up looks Great, nice and Clean, Low and Mean. Reps to you.
Bike Painter/Restorer and Aermacchi Nutcase !
