0 How stock is your bike
Last Post: SLW210
0 Mixture screw has no effect. Need help!
Last Post: AIE10
6 Is Your SPORTSTER...
Last Post: Sportycus
5 Your stomping grounds
0 Have I got my cam gears lined up right?
0 To lay it down or not?
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
0 Who's still riding???
Last Post: sleighcrane
0 How many amps does a 2003 XB charging system create?
0 Spokes and dual disc
Last Post: PetesPonies
0 IronHead Wire Diagrams Etc
Last Post: rubine
Last Post: Jollly Rogers
0 Memphis Shades Rio Grande & Trigger Lock
Last Post: ed_in_az
Last Post: ed_in_az
0 When Were You Born?
Last Post: MacSporty02
0 Cracked exhaust bracket short shots
Last Post: newroadster
0 Early/Late 73 case date code
0 seat bolt
0 Gravydog crashed again.
Last Post: gravydog
Last Post: rubine
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Straight 1" risers on 1200c
Last Post: chain
0 Lithium battery earthx
Last Post: SLW210
0 Happy Birthday Jarheads
Last Post: andy_t
  #51
Old 29th July 2018
nychopper nychopper is offline
Sportster/Buell Model: ironhead
Sportster/Buell Year: 77
nychopper is an unknown quantity at this point
I have not heard of this before, certainly not as a general principle or something to be expected.
I have had three head gasket leaks...
One was extremely obvious by the loud, squeaky sound of air escaping thru the space, in this video...
Head Gasket Leak
This was caused by some very bad machine shop work done to prepare that cylinder head for dual plugging. It was done by a shop that I should have been able to trust. My bad mistake
The second was a very interesting mystery. The leak was exactly adjacent to one of the oil drain holes, and on the inside edge of the hole. So the leak was entirely contained within the head. I really did not discover it until I had the head off. If I recall correctly there was excessive oil consumption or some other symptom, but I did not suspect a head gasket leak until I removed the head for whatever reason.
BTW, never clean up the oil on the cylinder head, gasket or on the cylinder itself before bringing it to a machine shop or other for examination. The oil etc patterns contain important information.
The third was the brother to #2 - the leak was adjacent to the oil hole, but on the outside. No air leakage sound like #1, but there was actual oil leakage - which is rare in head gasket leaks since the oil holes are such a small % of the leakable area.
This one required extra work because the head gasket is directly behind the middle pushrod tube seal. So that had to be eliminated as a possible source of the leak before calling it a gasket leak. For this I made a sandwich of two slices of paper towel with a slice of aluminum foil between. I stuffed that between the cylinder/cylinder head and the pushrod tube.
The oil migrated around between the fins and appeared on the cylinder side of the sandwich.
QED
I appreciate this! Well i think I'm throwing in the towel and bringing it to a shop. This is beyond me at this point haha.
thanks for all the help everybody! I'll update when I hear back from the shop
Old 30th July 2018
wedge's Avatar
wedge wedge is offline
You didn't even pull the heads yet according to the posts I see. Why would you give up before starting? It's not rocket science, it's just top end work, and you have the entire forum here ready to help as you go about it.
Old 30th July 2018
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Year: 1974
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
Also most part houses loan tools if you don't have what it takes.
Murphy's Law :vvet:
Old 17th August 2018
Any updates?
If you want to do something, you’ll find a way. If you don’t, you’ll find an excuse.
