0 How stock is your bike
Last Post: SLW210
0 Mixture screw has no effect. Need help!
Last Post: AIE10
6 Is Your SPORTSTER...
Last Post: Sportycus
5 Your stomping grounds
0 Have I got my cam gears lined up right?
0 To lay it down or not?
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
0 Who's still riding???
Last Post: sleighcrane
0 How many amps does a 2003 XB charging system create?
0 Spokes and dual disc
Last Post: PetesPonies
0 IronHead Wire Diagrams Etc
Last Post: rubine
Last Post: Jollly Rogers
0 Memphis Shades Rio Grande & Trigger Lock
Last Post: ed_in_az
Last Post: ed_in_az
0 When Were You Born?
Last Post: MacSporty02
0 Cracked exhaust bracket short shots
Last Post: newroadster
0 Early/Late 73 case date code
0 seat bolt
0 Gravydog crashed again.
Last Post: gravydog
Last Post: rubine
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Straight 1" risers on 1200c
Last Post: chain
0 Lithium battery earthx
Last Post: SLW210
0 Happy Birthday Jarheads
Last Post: andy_t
  #931
Sportster/Buell Year: 1988
I'm thinking the problem with my fender is caused by traffic lights, this thing really vibrates sitting at idle, and that's just above 1000 rpm.
That sounds likely. My Commando did this after it was dynamically balanced. All the vibration was deliberately in a narrow range just above tick-over but
thereafter it spun smoothly to beyond the redline. Fair enough as it was set up for racing but on the road I used to have to replace rear bulbs several times a week!
Old 5 Days Ago
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
part # 59674-81C* used from 83-03 ??
I'm not a complete idiot, some parts are missing.
Old 3 Days Ago
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
I may just get one in raw metal and attempt to weld the signal mount on from the old fender.
it's just a strip of metal with 2 holes in it welded to the bottom side and i think slightly raised where the holes are.
who knows .. maybe just leave the signals off make it look sleeker ..
Old 3 Days Ago
Nowadays I tend to run with indicators, as most car driver don't seem to know what hand signals mean anymore or are too daft to work it out.
Old 3 Days Ago
Yea, I was signalling the other day and the drivers oncoming thought i was waving at them .. lol . .
Old 2 Days Ago
Exactly!
