Last Post: RAIDER0372
Last Post: XL Ed
0 Small 1985 project
Last Post: detroiter80
0 Hello From Cayman Islands
0 2 into 1 exhaust build
Last Post: Four Speed
0 Reflectors...Yeah, or Neh
0 If you could only have one bike, would it be a Sporster?
Last Post: kopbilly1
Last Post: jharback
0 Forks and Triple Tree and wheels?
0 Sportsterpedia Progress
Last Post: Yakcm2
0 compression problems
Last Post: Sadsack
Last Post: MacSporty02
0 Nightster suspension upgrade (RK). Who has em?
Last Post: SportyHD
5 how does you Sporty start?
Last Post: SportyHD
0 Bent rear (Pingel?) motor mount
Last Post: nakina
0 HD 100th Anniversary Sporty Pic Thread
0 900 dual carb front head
10 What's your Personal Tech
0 Project Strociek
Last Post: simonster123
5 Summer time heat
Last Post: Eric Von Zipper
0 Do you like Brazilians???
5 Do you feel you pay too much for Motorcycle Insurance?
Old 27th June 2012
ibuiltmine ibuiltmine is offline
Sportster/Buell Model: 07 883 and 03 xb9
Sportster/Buell Year: 07
ibuiltmine will become famous soon enoughibuiltmine will become famous soon enoughibuiltmine will become famous soon enoughibuiltmine will become famous soon enoughibuiltmine will become famous soon enoughibuiltmine will become famous soon enough
Nope, It didn't fix it. It is the right turn signal, and on the front it doesn't flash the 'bright' element it flashes the running light element???
Old 28th June 2012
Sporting Lad's Avatar
Sporting Lad Sporting Lad is offline
Sporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud of
One of those two wires must have a bad connexion! I used a test light (available at any auto supply store, cheap) to check for continuity between the signal and the AMP connector. I'd suggest re-checking your splices.
It's not hard to fix once you've identified the culprit.
Old 11th August 2012
ColoRider's Avatar
ColoRider ColoRider is offline
Sportster/Buell Model: Sportster XL1200C
Other Motorcycle Model: Suzuki Bandit 1200s
Other Motorcycle Year: 1998
ColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the roughColoRider is a jewel in the rough
mine started doing the same thing on my trip to sturgis this week. the right front was blinking on the low filament, not the bright one. It flashes normal speed a few times and then fast. I haven't messed with the wiring. I washed my bike today and it blinked normal, but I only rode the bike for a mile or so... my butt still hurts from 1200 miles on a sporty. So confusing. I'm guessing it will come back, but it almost sounds like dust from the legendary buffalo chip got into my switch housing and when I washed it, something got rinsed out.
ibuiltmine - did you ever figure yours out?
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
its a common thing to get a bad ground and cause a fast flash or a flash through the runner as it looks for a ground there if the socket fails to ground the housing the filaments then ground out through each other causing a low light and normal flash. and sometimes a bulb shorts internally and an element falls over the other causing a short.
electrical GREMLINS are everywhere an tend to multiply if left unchecked so be a good pet owner and get your gremlins fixed we don't want them multiplying now do we !!!
Old 12th August 2012
Cool Gremlin invasion?
Ach! The very day after solving this turn signal issue my rear brake light switch bit it! Coincidence?? YES!! Strange, but true-- Two unrelated electrical malfunctions in two days.
Who does the MoCo get their electrical components from?
Lucas??
Well...that was all a few months ago, and nothing else since...
Old 18th June 2018
stray stray is offline
Other Motorcycle Model: Can Am Renegade 800X
Other Motorcycle Year: 2008
stray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant futurestray has a brilliant future
I'm having a similar issue with the right turn signal lamps flashing normal 4 times, then flashing fast (and it's only the one (driving light) filament working up front). When I test for voltage, I see that the terminal for the brighter filament isn't responding with the flasher activated on the right side, but is pulsing 12V on the left side. Am I correct in assuming that my issue lies between the socket and the turn signal module? Or, could there be a problem from the socket to the switch? I didn't begin to troubleshoot yet, but thought that since the switch is causing the driving light filament to flash, it must be working.
Old 19th June 2018
In stock form, both right-side TS bulbs are wired together using a Brown Wire (along with the right indicator) - Likewise, both left-side TS bulbs are wired together using a Violet Wire (along with the left indicator)...
Therefore, if one bulb (frt or rr) is flashing, so should the other one be flashing...
Is your right-side indicator flashing?? If so, then look carefully at the connector for the turn signals (likely under the tank)... Unplug it, clean it with contact cleaner, put some dielectric grease on the contacts & reconnect it together...
2 Relax
Old 19th June 2018
2 Relax
Thank you, I'll remove the tank and check the connections. Yes, both right side bulbs and indicator will flash 4 times normally, then begin to flash fast. The front bulb is only using one filament however, for both driving light and turn signal. I have replaced both front bulbs with new 1157s but to no avail.
Old 19th June 2018
Was this front wiring changed from stock? rewired in some way?
Sounds like a short - The Blue Wire for the Running Light (Dim element) should never be blinking - never getting power from the TSM - Right-side TSM signal should be on the Brown Wire (Bright element)...
Does the Rear Taillight blink with the Right TS?
2 Relax
Old 19th June 2018
No, it appears to be completely stock. The only things I've done recently were remove the speedometer to try and add a tach signal wire (you've been helping with that project as well, thanks again ) and things were fine after I reassembled. Then, I was going to replace the button covers as the labeling on them is a little faded, but the replacements I purchased didn't quite fit the Sportster buttons. So, it seems that the issue began when I opened up the right handlebar switch and messed with the switches. Maybe I pulled something loose from the connector you mentioned under fuel tank. Once the rain lets up, I'll look into that.
Yes, right rear turn signal will blink in sequence with the front (4 normal, then fast) as does the indicator light.
2 Relax
FREE Organized Tech Info - Check Out The XLForum Sportsterpedia[/QUOTE]
