Last Post: Medicalweed
10 Is it important to brush your teeth?
0 Who's still riding???
0 When Were You Born?
Last Post: Henry007
0 Hello everyone!
0 ***DK Custom - Pair of Quality Heim Joints For Harley Shift Linkage***
0 ***DK CUSTOM - Skid Plate for 2004-up Sporty****
0 I've been getting some revenge.
0 Led upgrade 1200S
0 Got New Bike - 2002 Sportster Project
Last Post: mzavala2424
0 primary and gear case cover paint.
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
0 Metal Polishing
0 no introduction needed
Last Post: 60weight
Last Post: SLW210
0 Royal Enfield V-twin concept at EICMA show
0 Chardhin moved to Pennsylvania!
Last Post: lostNdallas
Last Post: paulc
0 Shinko Tyre update - long and boring.
Last Post: slamtry
Last Post: Four Speed
Old 20th July 2018
Sportster/Buell Model: Xl1200S
Head identification (from DD) has been added to the Sportsterpedia here:
http://sportsterpedia.com/doku.php/t...identification
The history section also has some 73 changes including the L73 top end changes: http://sportsterpedia.com/doku.php/s...ection19701979
The only one elite in my life was a beautiful Australian Shepherd and I shot him for biting me.
Old 20th July 2018
doodah man's Avatar
Originally Posted by dilligaff1956 View Post
Ok. I'm joining in on an old convetsation...
this should clear up any confusion on what you need; have a look at this old conversation here...
[url]http://xlforum.net/forums/showthread.php?p=5133944[/url
• you beat me to it hippy!
Old 20th July 2018
Yep, that's the thread referenced in the Sportsterpedia.
Old 20th July 2018
dilligaff1956 dilligaff1956 is offline
Sportster/Buell Model: XLCH Sportster
Sportster/Buell Year: 1973
Sportster/Buell Year #2: 1973
dilligaff1956 is an unknown quantity at this point
WOW. Thanks for the info. Still confused. I need to order new head gasket. Trying to figure out how i can test how true the head or jug is as i definitely have a leak . I'm not rich. The shops out here in Edmonton want about 1 to 2 G just to do the top end. Its turning into a love/hate thing with this ride. But good excuse to get away from the wife of 35 years. Sorry got to work on the bike.
Old 20th July 2018
doodah man's Avatar
put the head back on the cylinder with no gasket, then see if you can get a feeler gauge to go in at any point around the joint. about .010" feeler is good. it's important to clean all the carbon off the fire ring and the grove it mates with in the head, and make sure the gasket surfaces are nice and clean and no big nicks/gouges. heads can be lapped to cylinders with lapping paste if they're not very bad, otherwise best left to a machinist to finish the surfaces.
Old 20th July 2018
you can't tell the difference between '72-e73 and Late 73 by the drain hole size,they're the same.look at the head bolt holes in your cylinders. '72-e73 threads come all the way up to top of the cylinder.L73>threads stop about 3/8'' below the top of the head surface.
Old 20th July 2018
Fridge's Avatar
Fridge Fridge is online now
Sportster/Buell Model: XLCH/H
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
+1 doodah, spot on.
