Last Post: BWP 5p
Last Post: Medicalweed
10 Is it important to brush your teeth?
0 Who's still riding???
0 When Were You Born?
Last Post: Henry007
0 Hello everyone!
0 ***DK Custom - Pair of Quality Heim Joints For Harley Shift Linkage***
0 ***DK CUSTOM - Skid Plate for 2004-up Sporty****
0 I've been getting some revenge.
0 Led upgrade 1200S
0 Got New Bike - 2002 Sportster Project
Last Post: mzavala2424
0 primary and gear case cover paint.
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
0 Metal Polishing
0 no introduction needed
Last Post: 60weight
Last Post: SLW210
0 Royal Enfield V-twin concept at EICMA show
0 Chardhin moved to Pennsylvania!
Last Post: lostNdallas
Last Post: paulc
0 Shinko Tyre update - long and boring.
Last Post: slamtry
Old 14th July 2018
jordan1200's Avatar
Default Question about dynamic timing a 2000i
I am going to dynamically time my single fire dyna 2000i and the instructions say to ground the VOES and put all dip switches to off. Run bike at 1500 rpm
What is the purpose of grounding the VOES ?
Doesn't it ground by the vacuum created while the bike is running? If so, why is it needed or suggested?
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
Old 15th July 2018
with the wire grounded, it forces the module to reach full adv at 1500 rpm, of note, you have to be above 1500 for the mark to fully be in the position of full adv. yes, it will adv on its own when started but this procedure makes it happen regardless of what the eng is telling it to do.
one? are you not suppose to select what curve you want as they have diff adv set points. or are you just wanting base timing?
Old 15th July 2018
jordan1200's Avatar
Yes you are supposed to select a curve. I did select curve 4. I wanted to time it dynamically so I could verify advance timing 2 dots according to the FSM is all..
I had to use a mirror cause I can't really see the timing hole with the current head pipe.
I may have to R&R the factory head pipe to be able to do it 100%. Something I have been avoiding..
Old 15th July 2018
rocketmangb's Avatar
Time it with the pipes off !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 15th July 2018
jordan1200's Avatar
Can't imagine how loud that must be.
Old 15th July 2018
its xxxxing loud !
Old 15th July 2018
jordan1200's Avatar
its xxxxing loud !
May not be the best idea in my quiet residential neighborhood..
Old 16th July 2018
jordan1200's Avatar
You said"
with the wire grounded, it forces the module to reach full adv at 1500 rpm, of note, you have to be above 1500 for the mark to fully be in the position of full adv. yes, "
Question:
If the module isn't grounded but connected to the VOES that will not have the full advance by 1500 rpm? Just wondering because I don't think the FSM actually says to ground the module only to confirm the VOES is working according to specifications prior to the dynamic timing procedure. However, I could be in error haven't read it in a while.
Old 24th July 2018
jordan1200's Avatar
When I dynamically timed the 2000i, the instructions said to place all switches in the off position. I placed all the switches to off except the one that places the module in single fire mode (switch 6). Was I correct to leave that switch alone?
Sent from my SM-T700 using Tapatalk
